Dropping one end of an attachment on the 422/425
   / Dropping one end of an attachment on the 422/425 #11
<font color="red"> Where's Charlie???? </font>
I'm here. Of course all I did so far is talk about it. In the scrap heap I have a couple of trailer axles. My thought is someday to put a wheel bearing and hub between a female and male attach plate and a small cylinder to rotate the implement with the aux pto. Just thinking stage so far, and unfortunately Bubenberg's prototype maker is piled up with top dresser and linear aerator prototypes. Maybe this winter we'll get to play.
   / Dropping one end of an attachment on the 422/425 #12
That's the trouble with Hans... all work and no play... those pictures of him riding the bucking PT are proof! /forums/images/graemlins/tongue.gif
   / Dropping one end of an attachment on the 422/425 #13
I think the rear wheel hub of a 89 chevy cavalier will work, too. I took one off once and it was only 3 or 4 bolts. A nice flat plate with the wheel hub on the other side ready to be welded to.
</font><font color="blue" class="small">( Bob. Tell us what you would be doing with this capability. Knowing what you want to do with a design always helps with the invention. )</font>
<font color="green"> </font> If the ground is not level you could tilt the bucket so that you could dig level. If you wanted to create a slope from level ground you could tilt the bucket.
Bob Rip
   / Dropping one end of an attachment on the 422/425 #15
thats easy to do now, just turn the steering wheel. the short side is always higher,the long side digs in. if that isn't enough do it over again.pile the dirt on the high side and all you need,it's easy /forums/images/graemlins/laugh.gif
Thanks, I will take a look at that tomorrow.
Bob Rip
   / Dropping one end of an attachment on the 422/425 #17
Hey, stranger! /forums/images/graemlins/grin.gif
   / Dropping one end of an attachment on the 422/425 #18
You could also lower one side of an attachment by letting air out from the tires.
   / Dropping one end of an attachment on the 422/425 #19
<font color="red"> You could also lower one side of an attachment by letting air out from the tires. </font>
But if you have your wheels inside out, you need to let more air out. (You awake Fourteen? /forums/images/graemlins/grin.gif)
   / Dropping one end of an attachment on the 422/425 #20
Maybe Fourteen is building an airplane, too?
2017 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2017 KOMATSU...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2010 Deere 318D (A60462)
2010 Deere 318D...
