Boondox
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 3,885
- Location
- Craftsbury Common, Vermont
- Tractor
- Deere 4044R cab, Kubota KX-121-3S
Near my house I have two trees that have to come down; both are the diameter of a telephone pole and about twenty feet off the ground they wrap halfway around each other so the crowns are intertwined. One is a dead Eastern White Pine that is not yet showing signs of rot, and the other is a healthy ash. I have a logging winch on my JD 4044R.
Unless I use the winch to redirect there is a chance the crowns will hit the porch. So here's my proposal.
Using a ladder, chain the two trees together as high as I can. Attach the winch cable.
Notch the dead pine. Even if I'm wrong and there is some rot at the base, the ash will support it.
Notch the ash.
With my wife using the winch to apply light pull, make a shallow falling cut in the ash (if the ash starts falling the wife will pull hard on the winch to pull the crowns away from the house).
With the tractor at PTO speed, use the winch to pull both trees down as I deepen the falling cut.
Sound like a plan?
Pete
Notch the ash.
Sound like a plan?
Pete
