drop speed on 5103
/ drop speed on 5103 #1
itsmegg
I am trying to adjust the 3 PH drop speed on a 5103 and I cant find the adjustment for it. I have a 5103 with hydraulics. The drop speed adjustment (according to the manual) is supposedly on the back right side of the seat. But I cant find it there. Any one know where it is??? Pictures?
The reason I want to adjust it is it drops too fast with the clipper attached.
/ drop speed on 5103 #2
If you can't figure it out from the manual, it's time for a quick stop by the Dealer's.
Unfortunately, there's no online manual for this tractor...
/ drop speed on 5103 #3
Mine was hidden by a wiring harness that was tucked up under the seat bracket. Take a flash light and on the right side of the seat (from a seated position), look under the bottom of the seat near where all the valves for the rock shaft and draft control are located. If you follow the rock shaft/draft controls inboard toward the transmission housing, you'll find it. The control is a very small shaft with a pin through it. The pin is movable through the shaft where you can get a hold of it. It's not very big and my 5103 is too far from me right now to get you a picture.
It took me three trips to the farm with the manual to find it, now the bush hog floats down nice and smooth instead of falling like a rock!
Here's the link to the Owner's Manual online: http://manuals.deere.com/omview/OMPY0142_19/
Thanks,,, I found mine under what must be the same wiring harness. The dude is hidden pretty good. I had looked 2 or 3 times and yesterday I made up my mind that I was gona find the darn thing, and I did.
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
2022 John Deere 5055E (A60462)
2022 John Deere...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2019 Ford F-250 Ext. Cab Pickup Truck (A61573)
2019 Ford F-250...
Deutz Engine Manuals (A63117)
Deutz Engine...
Diesel Engine Oil Tank (A61573)
Diesel Engine Oil...
