Drone suggestion
/ Drone suggestion #21
I had a Traxxa Aton for a while. It was a nice drone at a good price but it wasn't camera friendly. No integration. Had to manually attach/adjust/start the camera before taking off. And no remote viewing. Fun if you just want to fly for sport but probably not what you want. There are much better ones out there that seem to be able to hold their position better and follow filmed subjects. If you follow 'Our Wyoming Life' channel on YouTube they use one quite a bit for filming. As others have noted, the sound will likely be a challenge for getting near livestock. But you can see on that channel that they do pretty well around cattle with the one they have.
Rob
/ Drone suggestion #22
I have an FAA permit to fly my Drone. I'm not a commercial licensed pilot. FAA knows my Drone by it's serial number. There are very strict restrictions on where and how you fly. I am very considerate of violating people's space. I rarely fly in heavily populated areas and if so it's at events like at the local Dragstrip or a Parade. I maintain courteous height when near people. I don't want my Drone to be a nuisance.
FAA regulates my height at 400ft. Here's a pic from that height.
I believe everyone in the US needs to be registered with the FAA to fly a drone.
/ Drone suggestion #23
^ ^ Actually, each drone over 0.5 pounds must be registered with the FAA, but there is no restriction for recreational flying. If you are flying in pursuit of a business, you need to have a license.
I use a DJI Phantom 4 Pro+
It was almost $2000 but has one of the highest fellootin cameras in its class. I use it for footage in TV commercials.
Mine makes a racket, so you really couldn't sneak up on any livestock or anybody with it.
I have the FAA license, since I use it 'in the pursuit of a business,' and I have experience with jumping through hoops with the FAA. They can be problematic to fly anywhere around airports.
In this video, I had tower clearance to fly to photograph this airport's fly-in event, and I still needed an associate to walk with me to deal with all the angry pilots thinking I was an amateur hack flying around their planes. 2?19Wings&WheelsUpdate on Vimeo
I've also had to have my drone 'reprogrammed' to ignore its internal flight restrictions around major airports, because I fly it indoors in urban areas near Class B airports.
/ Drone suggestion #24
Yeah, it would be very hard to control. But could be easily enforced if checked. But who's going to check? I registered because I thought it was the right thing to do. I keep a copy of my registration in the Drone case.
/ Drone suggestion #25
DJI now $100 off. Mavic Mini now $399.
The mini gets you under the license requirement.
/ Drone suggestion #26
I didn't say everyone needed to have a drone license, I said needed to register. You're correct on the 0.55 pound exception. But it is not true that there are no restrictions. There are various restrictions including such things as distance requirements from an airport.
https://www.faa.gov/uas/recreational_fliers/
/ Drone suggestion #27
Thank you for clarifying. I should have said there are no restrictions other than the rules... and yes there ARE rules!
/ Drone suggestion #29
At least one TBNer has been posting videos from one. I might jump in.
/ Drone suggestion #30
I think I've had mine 3 years but maybe 4. Time flies. I have no idea how many flight hours I've put on it. Nothing like a commercial user would but several. When I'm flying regularly I'm pretty good with it. I've only had it out twice this Winter. So I'm pretty rusty right now. Have some projects to do with it when the weather clears. It'll come back to me pretty quick. :)
/ Drone suggestion #31
Here's a pic of my Drone. It will give you an idea of size. My Drone does not fold up so I transport it in it's hard case. Maybe Bunyip can post a pic of his mini drone.
If you want screen view capability my Drone requires the use of your cell phone or a tablet. I tried my phone but couldn't see it well enough for controlled flight. So I bought a 7x9 tablet. I like it a lot better.
Understand, once you launch you quit looking at the Drone and fly strictly by viewer. That's where experience comes into play. You have tunnel vision. My camera can only rotate up/down. It doesn't swivel. To see to the right, rotate the drone to the right. To see behind you, rotate the drone 180 degrees. Very common to be flying sideways, backwards, etc. That's tricky. If flying in trees it's easy to lose track of obstacles....
Funny. I had an Autel Robotics X-Star Premium (actually 2 of them) and a 2006 Rhino Sport Special Edition with the factory liquid metal vinyl wrap. We have similar taste!
I now would STRONGLY recommend to you guys wanting to see livestock that the DJI Mavic 2 Zoom is the one. The Mavic 2 Pro has a slightly better camera (so the camera geeks say.... I can not tell) but the Mavic 2 Zoom has an amazing mechanical zoom lense that actually allows you to view things from a much further distance. Think... not scaring the crap out of the cows, instead being curiously away and using the zoom to reach in.
Range... compared to my old Autel Robotics is staggering! The X-Star would struggle at 2 miles, the DJI Mavic 2 struggles at 5 miles!
Battery life on the Mavic 2 is consistantly in the 25 minute range unless your hot-rodding it. And the Autel does not monitor distance vs battery to determine return to home needs, but the DJI does this and shows you at all times as well as it will automatically take over and return to home if the battery level/distance/wind direction tells it that you MUST go back now. The Autel allows you to screw yourself up if your dumb enough to risk the machine.
The DJI flight control, speed, air brakes, and camera functions are the best in the industry. They are the Honda Generator of drones. Everyone else is some level below...
The Mavic 2 Zoom is a game changer.
/ Drone suggestion #32
My Autel monitors the battery, distance and conditions and will take over and try to come home when the battery is getting low. You can over ride that function and continue if your dumb enough to risk the machine. The farthest I've been away from mine is 3 miles. That was just to test it. Most times I'm within a mile.
The zoom lense would be a definite plus. Autel builds a compact version similar to the Mavic, can't remember it's name and don't know if it has zoom.
/ Drone suggestion #33
When I had the next star premium you could set a percentage of battery level that you wanted it to do an auto return to home, but it was not able to use software to evaluate the battery versus the distance and the wind speed. That's one thing that the autel didn't do that the DJI does very well.
Another thing that the earlier autel software did not do was airbrake well, the autel if you were going full speed and left off of the throttle input, it would drift many feet before it stopped often into a building or tree unless you manually applied full reverse thrust. The DJ I can be going 30 miles an hour in a direction and if you lift off of the commands it will flip itself sideways and fully thrust the opposite direction to stop motion. it will only drift a few feet before it's back in a rest, much more responsive.
/ Drone suggestion #34
Hmmm. I can preset battery condition in my Autel and as I said earlier, it will take over and come home when the computer thinks it needs to. A friend has had to go find his Mavic twice because he was flying at a long distance away and it couldn't make it back.
For those that might not understand, higher end Drones are very smart. It is constantly monitoring battery level and displays that on the screen. When it reaches a preset critical level it will take over the controls and either try to "come home" or land itself so it doesn't crash. Very good technology to have. It will also tell you how far away it is, how high it's flying, how fast it's traveling and what direction it is from "home". If you lose track of where you are you can hit the "come home" button and let go of the controls and it will return to the spot it launched from and land itself with no input.
The compact Drones definitely react to speed or direction changes quicker. They are a sportscar in that regard. If you are into hotdogging that's the way to go.
I've never went full speed toward a building or tree to within a few feet and then let off to see what the Autel would do. I think I'll pass on that one.
Friend of mine has the first edition Mavic which is slightly newer technology than my Autel. Him and I have flown together several times. We have raced, tested climb rate, tested stop rate, etc. In a couple mile run the Autel will outrun the Mavic by 30 seconds to a minute depending on wind. Climb rates were the same. Stop test the Mavic was considerably quicker due to it's smaller size and weight as I described above.
As with any technology the offerings are endless. And especially important, you get what you pay for. High end results require high end expenditures. Also check the accessories that come with a Drone package. Most only have the Drone, Props, one battery and a charger. So check prices on additional batteries and chargers if you plan to fly much.
I would be hesitant to buy a Drone that wasn't equipped to take care of itself as in "critical land" when battery is low or know how to "come home".
/ Drone suggestion #35
Okay your autel does what mine did, where you preset a condition in the battery at say 35% it will always return home. That's not what I'm talking about with the newer DJI products. what day do is monitor what kind of amperage is being pulled to run against the wind, what the battery percentage is remaining at any given time, what distance you are away at any given time, and it is calculating how many amp hours of battery life it will require and it will constantly adjust the return to home amount of battery required and whenever you cross the threshold that it needs to react it will automatically take over and bring the drone home. on yours if you set your battery to return to home at 30% remaining, and you drive the entire 70% of the battery away from you with the wind, your drone is not going to make it anywhere near back to you. That's what the DJI does differently, the DJI realizes that the ground speed is much too high since the wind is at its back and the amperage draw is much too low for the given ground speed. So it can backward calculate what the wind speed would be and how much battery power it would take to get it back. So as your distance is changing the battery percent required to return to home is going up on your display, as the wind affects the unit the battery amount required to bring it home goes up or down, so everything is being calculated so that no matter the distance the wind the speed or anything else the machine is constantly calculating and correcting the return to home battery remaining critical amount. It is in live time being changed right in front of you.
/ Drone suggestion #36
This is a short video which shows the stability
Iain Lamond on Vimeo
Be very aware that return home is the takeoff point and not the controller and it takes the drone to its maximum altitude for the trip.
Sound is my lute I finally tuned.
/ Drone suggestion #37
Hmmmm... Why did my friend have to go find his twice?
/ Drone suggestion #38
Very nice! Those paintings are pretty cool too. Someone had a tall ladder.
/ Drone suggestion #39
Or a long arm;)
I've had mine for about three years I think, still on the original props but you can buy quieter ones, the latest Mavics come with the quiet props, Richard was the one who led me on this slippery slope and I was impressed with the Autel quality but, always a but, we can't get them here but the other big names have an established presence.
The rules here are much the same as your FAA, ours is CASA, 400 foot ceiling, no flying over people or events, no flying over emergency scenes, the list goes on, most is common sense but you see it being breached all the time.
I haven't had it out for a while and I forget how to calibrate the compass but if it needs doing it won't take off and will prompt me how to do it, I also like the auto take off, just leaps to 4' and just sits there waiting for further instructions, impssible to crash land, just push the down control and it will drop to 4' then land itself gently, they are pretty much idiot proof but some manage to prang them, the collision avoidance turns off in sport mode but I have never used it.
At about 50' you barely hear them, at 100' you wouldn't know it was there, you are supposed to keep eye contact but they are easy to lose sight of but the camera helps you navigate home until you hear and see it again.
A bit of practice gives you smoother control unlike my first video (DJI 004 on the link) and you can adjust how smooth you want it to be, the aperture on the camera is fixed but you can get ND filters for really bright days and polarising filters, I think I paid about $100 for a set which are ND4-8-16 and polarising.
The latest Mavic has a longer flight time than mine but only about 3-4 minutes which in the scheme of things is not much.
I discovered one day it has a high wind warning, I was up about 200' and it was being buffeted around something shocking and I was alerted that wind was exceeding 60kph, drone was not happy and couldn't stabilize in the gusts but came down safely.
/ Drone suggestion #40
I'm guessing older/earlier versions?
The Mavic 2 has sonar and visual cameras facing up, down left and right to "see" obstructions, and it can see forward 3 dimensionally to work out paths around, over or under an object. I had 2 if the Autel units, and they were fantastic back when new. But they are very dated today. I actually gave mine away to the daughter of a work buddy. She's still flying it.
But the lastest and greatest.... It's like comparing a 2 generations old car/truck to a most recent and modern generation. Everything has changed, and everything is better and smarter.
I loved the Autel at first, but the companies horribly slow updates and false support.
But these.... Cameras front, back, sides and down. Sonar all over. Cameras pans from level like yours and down, but also up, left and right.
Aluminum main body and aluminum arms. Not the Autel cracky plastic.
I was a huge anti DJI and a huge Autel fan boy for a couple years. But that time passed for me. The Autel was a great unit though, and for it's time it had a fantastic camera! JPEG_20200416_210704_6077373194636232786.jpgJPEG_20200416_210918_4033460287693030689.jpgJPEG_20200416_211043_1185728976220756219.jpgJPEG_20200416_211112_7233633654407271987.jpgJPEG_20200416_211138_8120596037849922207.jpgJPEG_20200416_211210_6209742147767362546.jpg
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
INTERNATIONAL 720 - 6 BOTTOM PLOW (A63291)
INTERNATIONAL 720...
2005 Butler pole trailer (A62679)
2005 Butler pole...
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
