Driving over a septic tank
   / Driving over a septic tank #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
I have an LS 4140 with cab and loaded tires. Estimated weight is 5500 lbs.
Would it be safe to drive over a septic tank buried 10” below grade?
   / Driving over a septic tank #2
Lot of weight for plastic pipes running to and from. But then again, I drive 3k# over mine on occasion. My pipes are a bit deeper though.
   / Driving over a septic tank #7
If it is a flat top tank you might be going for an unpleasant swim. If round tank they are less susceptible to collapse.
I have broken through the top of an unknown abandoned tank and it does surprise you to point of needing septic service 💩
   / Driving over a septic tank #9
Septic tank shouldn’t be an issue if it’s at proper depth, and in good condition. I drive over mine pretty often.
The leach field is a different story. I avoid compacting the soil and possibly cracking pvc pipes
   / Driving over a septic tank #10
Round tanks here (one septic and one pump because the drain field is higher). The pipes are a couple feet down. Drain field is PVC in a thick stone bed with at least a foot of soil over it. the only thing I don't drive over would be the concrete lids. I won't say it's the best practice, but that's what I've been doing since 1990.
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2018 Lexus IS300 Sedan (A55853)
2018 Lexus IS300...
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
CATERPILLAR CS54B ROLLER (A52707)
CATERPILLAR CS54B...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
