Driveway Gate Install
/ Driveway Gate Install
You might want to leave them loose if you are at all OCD. That way you can rearrange the blocks, get them straighter and more uniform in color :D On the other hand you are in CA, you might want to set them permanently so you don't have to restack them after an earthquake :D
Nice work, looking forward to more pictures.
I am OCD, for sure. So much so that when I posted the last picture of the gate, it looked like the opener arm on the left was tilted. I went out and measured it and sure enough, it is an inch and a half low. The gate still works fine as there is no pressure on any mechanical connections because the arm has a swivel joint. Just the same, I'll be out there grinding the bracket off and re-welding it soon.
As for reflectors on the gate itself, that's one reason I posted this project, for great ideas like that. Thanks guys.
More pics soon. I poured the other column foundation today. Almost time to rumble......stone.
/ Driveway Gate Install #83
Some of that reflective tape for trailers on the center uprights should make it visible at night; it might detract from the looks a bit but not nearly as much as having it run into, I've seen my share of that.
Another thing that you might consider for final assembly when all the fussing is done is to replace the hitch pins on the opener arms with something like a bolt with a nylock nut or other tamper resistant fastener. Granted, people can walk by it, but if someone wanted to drive in making it more difficult could deter the hit-n-git types.
/ Driveway Gate Install #84
Is this gate located right at your property line? If it is over your line by 30' or so, I would strongly recommend a turn around lane. It's no fun to pull up to a gate, get denied access, and then have to back your way out a long road till you find a driveway you can back into.
Since this is a tractor site, I figured you already have the equipment to build it, you just need the gravel etc. Just make sure you are home or leave the gate open. :).
This brings up another major point. I think I saw that you have a keypad set up at the entrance. Do you also have a call box that will ring to the house when the gate is closed and you have visitors?
If you have good cell service, it's not a problem thay can call the house and you can give them a code.
A better way is to have a phone entry system where they push a button and it rings to your phone. You just press a number on the dial pad and it lets them in. You can even get them with cameras so you can confirm that it reall is the UPS driver etc. You can also program the gates to stay open during the day and close at night if you have a seven day event timer built in.
Also want to mention a Knox fire switch or SOS (siren operated sensor) that will recognize the sound of a fire truck alarm. This is in case there is ever an emergency at the house and the gate is closed.
These are all items that can be added.
What you can't tell from the pics is that there is a turn around thirty feet before the gate.
I don't have a call box. We figure that it's a long drive for friends without calling first to see if we are home. That's something that has only happened once or twice in thirty years. They can use their cell phone from the gate if necessary.
The control box has timers and settings for most situations but we want the gates to stay closed at all times. Patterns of open and closed conceivably could be noticed by undesirables but out here, I would probably see them before they see me.
I'm hoping any fire crew will have the presence of mind to unhitch the arms and swing the gates open.
Thanks for all the suggestions, I appreciate the thought you all put into this.
/ Driveway Gate Install #87
I don't have a call box. ....... They can use their cell phone from the gate if necessary.
yep, on the cell phone.
I have a Knox box on mine. There must be a way to wire in a special key switch. Or the code is in the Knox box
/ Driveway Gate Install #88
For security its worth noting you can likely push these open by hand with a bit of effort. A car would push right through. You can get magnetic locks and such that help with that, but gates of this style are more ornamental to keep out most honest folks vs true security barriers. Most people would move on to an easier target, if there is a gate there likely are other security measures too.
/ Driveway Gate Install #89
In Olympia I had to give up on the gate idea after it was forced on three occasions... it was a nice gate with opener...
First two times the mighty mule opener was trashed... went to a more robust opener and the gate hinges ended up being mangled...
Plan to revisit it and when I up there permanent...
/ Driveway Gate Install #90
Troutsqueezer,
You seem to be on top of most of the options, and I commend you on a job well done. It really looks great and your welding of the hinges and operator brackets look top notch. The style is really nice. Can you tell me where you got it from. You may have mentioned previous, but throw in another plug. You did their product justice.
In case of an emergency, most fire departments won't stop and look for a pin to pull, they will just plow through the gate to find the emergency. I would really reccomend Knox box or SOS unit. It's worth the investment for both piece of mind for your gate and safety.
If you can see the gate from your house they also ale long distance transmitters and receivers that might be able to open the gate from up to 1,500' away rather then just a couple of hundred.
Have you shot a video of them working yet?
Exactly.
Troutsqueezer,
Thanks again for the compliments, guys.
The fire engines around here are 4WD. I hope they find a way around the gate.
I had the gate custom built from a place called Irish Iron located in Carmichael, CA. A suburb of Sacramento. It was around $2,500 just for the gate. Total cost of the install will hit $5k.
I may go with a wireless box of some kind. Something to think about during the long, hot days of Summer. It's about 660 feet to the house.
This morning's work. My Tacoma PreRunner can haul 1,500 lbs in the bed so I am hauling 30 bricks at a time which is a little over 1,200 lbs. I have to make four trips to get it all. Didn't take long to stack them. That's the best part about this particular method.
/ Driveway Gate Install #94
Looking real sharp...
/ Driveway Gate Install #95
I may go with a wireless box of some kind. Something to think about during the long, hot days of Summer. It's about 660 feet to the house. I'm just over 500' and NOT line of sight. Had a problem finding a good wireless intercom/opener. Found one for $500 that is a cell phone. It has a single button call box that calls my cell whenever someone pushes it, where ever I am. I enter cell phone numbers that I want to have access and it opens for them when they call the gate. I also have buttons in our cars, but if someone comes, pushes the button, and I want to let them in, I can open the gate from where ever I'm at.
Last pic to finish off the thread. It was an enjoyable project that I spread out over a couple of months or so, a couple of hours about every other day out in the morning sun, listening to R. Limbaugh (sorry, liberals :)) Eventually we will put some sort of statue on the tops of the columns. I'm leaning towards griffins or gargoyles. The wife probably wants some sort of lion but we'll see. Still to come is the metal estate sign that we ordered online.
Thanks to those who followed the thread and provided comments.
/ Driveway Gate Install #97
Looks great and makes for a nice entrance to your home and will keep strays out... well done!
/ Driveway Gate Install #99
Great Job!
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2018 CAT D6TXL DOZER (A67714)
2018 CAT D6TXL...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
Sandblast Pot (A68134)
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
