Driveway Fix
/ Driveway Fix #1
TractorTeen
Virginia
Kubota B2910
I have crush and run coming in tomarrow morning for my driveway. I have been working on it with my blade trying to fix the problem. I think I have come up with a good solution. As you can see somewhat in the pictures I have ran a ditch down the side of my driveway all the way into the woods. I am going to put rock that is about 2 - 2 1/2 inches big in the ditch and crush and run on the driveway. I think this will work good. Look at the pictures and compare them to the others and tell me what you think.
Thanks
/ Driveway Fix
Another Picture of the driveway fix
/ Driveway Fix #3
The pictures are taken too close up for me to get a good idea of the way the land slopes on either side.
At my place just removing all the trees from the house site has added a lot to the run off. My worst place is on an off camber curve where the water runs over the drive. There is a lot of shale under a shallow layer of clay so ditching isn't the answer, I had to turn the water out before it got there.
Your ditches look like they'd do a good job of keeping it off the drive, but I still can't tell if the middle of the drive is lower than the edges.
/ Driveway Fix
It is put I am going to build the center up and grade it to a slant on each side so the water will run to the side. Than the ditches will carry it off. It was hard for me to get a big picture of the whole thing and than have it under 100000 bytes. Gravel is suppose to be coming this morning so I will see what I get and give some more pictures.
/ Driveway Fix #5
What you're doing sounds reasonable. Do whatever you can to get some compaction into the gravel. I douby if running over it with you wheels will be enough. You may want to rent a roller.
Increasing compaction lkeepe the water out of the gravel, and makes it more resistant to erosion.
/ Driveway Fix #6
Everything you ever wanted to know about private gravel roads.
Maine camproads (pdf)
You may want to consider some geo textile material under the gravel - do a search here on tbn it has been discussed before
Good luck & enjoy the seat time
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
EZ Trail 3400 (A63688)
