Driveway Drainage Help.....
/ Driveway Drainage Help..... #1
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Afternoon Guys,
I know there are a bunch of you guys that have much more experience on drainage issues than myself. So here I am.
My Vt driveway is approx 800 ft long. The first 200 ft are relatively flat, where I am taking the picture from, and from the pine tree on the left until you reach the utility pole its quite steep. In the steep section I unfortunately have a seasonal spring and water come out on this section. I would like to put some drainage in this section to keep the ice from always being an issue and also keep the washouts to a minimum in the warmer months. There is a swale on both sides of the driveway for snow and rain water runoff. My thought was to put some type of french drain in this section and then use some 45 elbows when I get to the bottom. What do you all feel is the proper way of doing this ? Just to give you an idea, I couldnt get the Massey up that section with chains in FWD. It was solid ice :eek: I ended up on my butt twice trying to spread sand to make it climeable !
All suggestions are welcome ! :) My butt still hurts !
/ Driveway Drainage Help..... #2
Scotty - you have a problem!
Chances are drains are not the answer as they will freeze. More of a backslope may help by giving more room for the ice.
My only suggestion would be a rear ripper/ scarifier and almost daily maintenance to keep the ice at bay.
Evenin Egon,
That doesnt sound too good :( I cant be there daily because Im only there on the weekends :confused: The sand worked good but only after I put it down ! Myself included ;) Maybe a 3 pt hitch sander ?
My farmer neighbor up the road suggested going around the outside of the field on the right to alleviate the steep section but that would make the drive 1500 to 1600 ft long :eek: Guess I better think awhile on this one ! Thanks !
/ Driveway Drainage Help..... #4
This may be overkill, but could you keep the same basic path but put in switchbacks to reduce the slope that your vehicle has to climb?
/ Driveway Drainage Help..... #5
Scotty, your neighbour may have a good idea. Winter time and water seeping out of a side hill can be very hard to deal with. Either hope for real cold weather or real warm weather. In between the water keeps running and freezing.
I've seen this quite a few times on ski trails in the mountains. It can get real interesting either climbing up or going down.:D
Mornin Z and Egon,
Thanks for your replies ! I will get some supposed experts up there this spring and see what my best option is $$$ ;) :)
Thanks for your suggestions !
/ Driveway Drainage Help..... #7
Hi Scotty,
I sure love to see your pictures and how pretty it is in your part of the country!!!!
Thanks,
Eddie
/ Driveway Drainage Help..... #8
Scott,
There is an old saying about road building ... " Get the water off and the rock on" ... basically you need to just raise the road some ... get a good drainage with ditches on the sides to divert the water away from the road and keep a nice surface of rock and a good crown on the road. That spring's water needs to be diverted away from the road but I don't think the french drain will handle that job very well ... an intercepter ditch to divert the spring's water away from the road or carry it along the side of the road maybe the best way to handle this water. Beautiful place you have there.
Leo
Mornin Leo,
Yep, I think you and Egon hit the nail on the head ! To begin with I dont have any crown on that section of the driveway, thats part of the problem. And as long as water is flowing there is no real way to stop the ice.
Thanks for your thoughts.
/ Driveway Drainage Help..... #10
That spring water doesn't follow a ditch very well when the temps below freezing. It just keeps piling up and up and !!:D :D
Darned -- slipped on the ice again!:D
/ Driveway Drainage Help..... #11
Dig a big hole and put in an underground cistern. Sell that water!! "Some" people pay good money for bottled spring water.
scott_vt said:
Mornin Z and Egon,
Mornin Egon,
Sorry about that post ! I kind of remember looking at your profile some time ago.
Egon = civil engineer = expert......... sorry :eek:
/ Driveway Drainage Help..... #13
Correction Scotty,:D I'm not a Civil Engineer:( nor am I an expert on anything. :(
In a very few areas of narrow perspective I know just enough to be dangerous.:D
/ Driveway Drainage Help..... #14
Hi Scott
First you really need to find the source if in fact it is under your road. You then would dig down deep enough to get under it. At this point you will need to pour a concrete trough or a good system of rock so you can drain to either side of your road then cover it up. Always try to keep at least a .25" to .5" slope for drainage per foot. If you do much more than that you stand the risk of etching on the ground. The crown will be very important as well.
One thing to remember is if you just cover it up (with rock or anything else) there will be problems later.
The reason I say the "source" is maybe it is not under your road and you could then divert the natural flow elsewhere. If it is in a line across your hill that will be harder. The thing to remember is give the water somewhere else to go. It will always take the least resistive path. Some more pics of the area in question would be helpful. It is kind of hard to completely understand without some more info.
Shane
BTW I work for an environmental engineer/survey and if I had better pics I could give you better answers
Mornin Shane,
Sorry I didnt see your reply until today :confused: Come spring time I will post more pics. In spring you can actually see the water bubbling out of the driveway surface on the steep section !
Guys down south are putting gardens in allready and Ive got to wait at least another month before I can get the shots your looking for :confused: :)
Thanks Again !
/ Driveway Drainage Help..... #16
No problem scott.
Just post them to this thread or PM me.
Shane
/ Driveway Drainage Help..... #17
In regards to the civil engineer = expert comment, well.... civil engineering is a broad discipline and some don't know diddly squat about roads. I am a civil engineer but will always lean on the experience of the folks that have been there and done that.
Dealing with ice flows is more challenging than just dealing with water. I could easily lay out a ditch system to keep the road dry and solid unless it freezes and the ditches plug with ice. Be sure to follow the advice of someone familiar with your ice problem.
Another good saying I picked up somewhere is "a road without a ditch is a ditch".
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
3" Steel Posts (A66408)
3" Steel Posts...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
Heavy-Duty Round Livestock Bale Feeder (A66408)
Heavy-Duty Round...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
