Pirate
I have a slope of around 400' that we are going to get paved with concrete, 6" thick, 12' wide. What do you think that would cost? Thanks.
Paying someone. I don't have a clue about concrete or measuring, etc. How big is a yard in concrete terms?
Here's an easy way to calculate concrete, or dirt, gravel...any material in cubic yards.
Length in feet X Width in feet X Depth in inches - Divide by 324 = cubic yards
RB is right on the calc for cubic yards for your driveway at 44.44 cubic yards. Depending on how skilled the contractor is at grading, he will probably order 45 yards+.
There are a lot of variables as far as pricing goes and I would set the specs so that each of your three contractors giving bids are giving you an apples to apples price. What type of sub-base will he use? Will he compact it? Will he use standard 5 sacks per yard concrete with 3/4" rock? Will he use a plastisizer, water reducer or add fiber? A 6" slab will usually call for 3/4" (#4) rebar. The contractor will spec the rebar spacing in on-center-each-way measurements. Could be 15" OCEW, 18" 24" or anything in between. He might even specify mesh in place of rebar. What is his spacing on control joints? All of these variables affect the price, including the finish.
Around here a driveway at 6" thick would run anywhere from $13,200 to $16,000 for the same basic specs. Some yahoo will always come in substantially less. I throw the lowball bids in the circular file. That said...with the state of our economy there are some very good contractors without much work, so you could find yourself getting a pretty good deal.
I ran your numbers through and your calcutation comes up to 48.888 yards, too.![]()
Try it again. 200x12x6 / 324 = 44.444444
