Drivewar culvert repair
/ Drivewar culvert repair #1
oldgrizzlybear
NW Mississippi
Yanmar 1500D
The culvert under my drive is rusting out. This is a fairly large culvert approx. 2 feet in dia, and about 26 ft long. What I would like to do is sleeve a slightly smaller plastic culvert inside the existing culvert. This should still give me enough capacity. I'm wondering if the switching from galv. metal to plastic culvert will have the same effect as with water pipe: you can go one size small and keep the same flow. Has anyone done this? Any advice would be appreciated.
Larry
/ Drivewar culvert repair #2
Yes I have..but make sure its a straight run for the culvert..no angles
Thanks, yes its straight. Did you seal the two together any way. I'm worry about the water washing around the insert.
Larry
/ Drivewar culvert repair #4
Larry, check out this link, it has instructions for installing culverts as well as maintaining dirt/gravel roads
<A target="_blank" HREF=http://www.state.me.us/dep/blwq/docwatershed/camproad.pdf>Maine Camproads (pdf)</A>
/ Drivewar culvert repair #5
No I didn't seal the insert,for in time the gravel & dirt fill between the two culverts..the dump end of the culvert I did pack w/rocks so the gravel so the water wouldn't push the gravel thru.
/ Drivewar culvert repair #6
I've run plastic inside plastic to increase the crush rating when I could not bury the culvert as deep as I would like.
The problem I've seen with steel culverts is that they rot out on the bottom and collapse, what originally was a round 2' culvert may look more oval than round after 20 years.
It's worth a try, if you cannot get a new culvert pushed thru the old, you can always dig it up, (more seat time).
/ Drivewar culvert repair #7
If it's on the county right of way I'd call them and see what you're allowed to do. Around here if you get creative you can come home and find the whole mess dug out.
/ Drivewar culvert repair #8
Be sure and check with county. In my area you buy the first culvert and they maintain/replace from then on....
If its on your property then removal might be the best option as rust thru may complicate inserting the plastic tile. Just a thought.....
Jim
/ Drivewar culvert repair #9
Larry , I used a piece of this double walled PVC for my culvert. TSC carries it in 15" ID X 20' long. The OD is about 18", but it needs to be double walled for strength. Don't know if it comes any larger or not. The nice part is that it is designed with an "O" ring to allow it to fit end to end, and you can cut it in half to haul in a pickup or van and then put it back together, and one man can handle it.
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2024 Blue Diamond Trencher (A63116)
2024 Blue Diamond...
2020 Inifiniti Q 50 Sedan (A61569)
2020 Inifiniti Q...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
