On some tractors, that only works if the PTO is engaged.
My guess with this incident, the tractor may have had the key in the switch or had been idling and someone jumped in and put it in gear (then jumped out). Although an operator error (most likely), I doubt it was an authorized operator error.
That tractor is a JD. Almost certainly it has a PowerReverser tranny which is what I have on my tractor. I cannot see how that tractor was running without an operator unless the safety devices failed or where disabled. I can leave the engine running and get off the tractor. However the tractor cannot be in gear. If it is in gear and I get off the seat, the engine turns off. Usually this happens in the winter when I have a long heavy coat...
The PowerReverser tranny has THREE different levers to engage the gears. One is for the range, A, B, or C, and another is for the actual gear, one to four. These two levers are to the left of the operator below the seat. The other lever is on the dash. It puts the tranny in neutral or tells the tractor to go forward or back. The operator uses the third lever all of the time. The other two are not usually used that much.
All three levers have to be in "gear". Any one of them in neutral will prevent the tractor from moving.
I know that the engine turns off if the operator is not in the seat and the tranny is put in gear, because every winter, when wearing a long, heavy jacket, it is easy to knock the dash tranny lever from neutral to forward or reverse. At which points the engine starts to stall.
If the tranny is put into gear, with no operator in the seat, the engine stalls. If the safety devices are working.
I searched for more information about the incident but did not find anything.....
Later,
Dan
