Drive chain adjustment on KS66-220fm
   / Drive chain adjustment on KS66-220fm #1
K man
Platinum Member
Quadeville, ont
2014 Kioti CK 30 HST with cab. 2018 Cub Cadet Challenger 750 EPS UTV
Hi I am wondering what is the tension the drive chain on my KS 66 front mount blower be. I turn the drive shaft and see the chain is not touching the sprocket till I turn the shaft about 1-2 inch. Should chain be loose while disengaged or should it be on the sprocket. Thanks for any advice and pics of what chain tension should be.
Thanks
Gilles
What nobody here has a Kioti snow blower. lol
   / Drive chain adjustment on KS66-220fm #3
I have the 72" blower so I don't know if it's the exact same, but once I hit the end of my adjuster I removed the half link in the chain and reset the adjuster.
Once I reach the end of my adjuster again, I'll remove a full link and insert the half link again and repeat.
Jason
Ok, here is what I meant. The idle sprocket is not touching the chain unless I turn it a bit. Is this normal or is it too loose. Thanks for any help.
Gilles
Ok, went to the dealer to get my answers. Jason, sorry I did not explain it in my question and revised it. If your blower is a Kioti KS72 then it is basically the same other than the size. Thanks for your input.
Gilles
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
2015 Dodge Journey SXT Van (A56859)
2015 Dodge Journey...
2015 EAST MANUFACTURING ALUMINUM STEP DECK (A58214)
2015 EAST...
1986 VIM TACK TANKER TRAILER (A58214)
1986 VIM TACK...
