Drive chain adjustment on KS66-220fm
   / Drive chain adjustment on KS66-220fm #1
K man
Platinum Member
Quadeville, ont
2014 Kioti CK 30 HST with cab. 2018 Cub Cadet Challenger 750 EPS UTV
Hi I am wondering what is the tension the drive chain on my KS 66 front mount blower be. I turn the drive shaft and see the chain is not touching the sprocket till I turn the shaft about 1-2 inch. Should chain be loose while disengaged or should it be on the sprocket. Thanks for any advice and pics of what chain tension should be.
Thanks
Gilles
What nobody here has a Kioti snow blower. lol
   / Drive chain adjustment on KS66-220fm #3
I have the 72" blower so I don't know if it's the exact same, but once I hit the end of my adjuster I removed the half link in the chain and reset the adjuster.
Once I reach the end of my adjuster again, I'll remove a full link and insert the half link again and repeat.
Jason
Ok, here is what I meant. The idle sprocket is not touching the chain unless I turn it a bit. Is this normal or is it too loose. Thanks for any help.
Gilles
Ok, went to the dealer to get my answers. Jason, sorry I did not explain it in my question and revised it. If your blower is a Kioti KS72 then it is basically the same other than the size. Thanks for your input.
Gilles
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
30in Hydraulic Forks Skid Steer Attachment (A56857)
30in Hydraulic...
1991 Trail King Trailer (A55973)
1991 Trail King...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
