Drive chain adjustment on KS66-220fm
   / Drive chain adjustment on KS66-220fm #1
K man
Platinum Member
Quadeville, ont
2014 Kioti CK 30 HST with cab. 2018 Cub Cadet Challenger 750 EPS UTV
Hi I am wondering what is the tension the drive chain on my KS 66 front mount blower be. I turn the drive shaft and see the chain is not touching the sprocket till I turn the shaft about 1-2 inch. Should chain be loose while disengaged or should it be on the sprocket. Thanks for any advice and pics of what chain tension should be.
Gilles
What nobody here has a Kioti snow blower. lol
   / Drive chain adjustment on KS66-220fm #3
I have the 72" blower so I don't know if it's the exact same, but once I hit the end of my adjuster I removed the half link in the chain and reset the adjuster.
Once I reach the end of my adjuster again, I'll remove a full link and insert the half link again and repeat.
Jason
Ok, here is what I meant. The idle sprocket is not touching the chain unless I turn it a bit. Is this normal or is it too loose. Thanks for any help.
Gilles
Ok, went to the dealer to get my answers. Jason, sorry I did not explain it in my question and revised it. If your blower is a Kioti KS72 then it is basically the same other than the size. Thanks for your input.
Gilles
Hesston 1120 Haybine (A50774)
Hesston 1120...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
Chery 20'x20' Steel Carport (A50121)
Chery 20'x20'...
Gehl 2580 Round Baler (A50774)
Gehl 2580 Round...
