drilling holes
/ drilling holes #31
Use an old time Cole Drill - it is amazing what they drill through turned by hand.
Ken
Good Idea. With a good quality bit and a small pilot hole to drill a 3/4 hole through a 3/4 piece of steel is reasonably quick and easy with a Cole Drill.
Using a decent drill bit and the slowest speed on a drill press the same thing should not be a problem.
/ drilling holes #32
Two things to stay away from in the Chinese tool arena are Drill bits and taps. Total junk. I bought a set of titanium nitride bits and every one of them needed sharpened. And it didn't take long before I untwisted and broke one. Knowing this would I buy a 3/4" bit for $9? sure if I knew I would only use it for 3 holes total. But since a quality bit that size is about $85, it should be obvious that something is up.
/ drilling holes #33
Too much is expected of titanium nitride bits; Ti-n is nothing more than a ware coating like black oxide. It is the base steel that counts. Many Ti-n bits are nothing more than wood bits with a Ti-n coating. Even a cheep set of cobalt bits will out last Ti-n bits. Sharpening is a science and art; the general point angle is 115 deg, sharp point for soft stock like wood, plastic and a flat point for hard stock. The clearance angle behind the cutting edge is critical too, if it is too thin the cutting edge will chip and if too thick the cutting edge will skim over the stock. There are sharpening tool that are adjustable that gives you control of the point shape. Worth the investment? That depends on how often you need to drill holes.
http://www.woodcraft.com/Articles/Articles.aspx?articleid=267
/ drilling holes #34
Twist Drill Sharpening Tips
My only expectation upon purchasing them was that they be sharp and drill mild steel. They did not meet my expectations!
/ drilling holes #35
Thanks all....Maybe I burned these up and they need sharpening....I have never sharpened a bit....how is that done?
If you "burned them up" you changed the temper and sharpening won't have the desired result. You didn't mention cutting oil/fluid, but nearly every poster mentioned it ...it is absolutely essential ...and, when things are just right--the down pressure, the drill speed, and the sharpness--you get beautiful spirals, the proof that you've dialed in all the parameters just right.
As for the cutting fluid, it should be plentiful enough to cool...if you can't apply continuously, you might build a little well around the hole...maybe plumber's putty, to keep a little lake of fluid at the cutting edge.
/ drilling holes #36
As for the cutting fluid, it should be plentiful enough to cool...if you can't apply continuously, you might build a little well around the hold...maybe plumber's putty, to keep a little lake of fluid at the cutting edge.
Now here's a guy that's done it......I drill all the time with huge drills and they never touch the stock without coolant/water......
/ drilling holes #37
...you might build a little well around the hold...maybe plumber's putty, to keep a little lake of fluid at the cutting edge.
I agree with wdchyd. That's a pretty good trick. I may keep my putty by the drill press now rather than on the other side of the shop.
/ drilling holes
The responses to my questions are just terrific and why this forum is great.
I can get my drill press to move a little slower but not much. I did sharpen my bits and may be that will help. I usually spray WD40 while drilling but I guess that might not be the right product to use. I also get a sense that you have to put a fair amount of downpressure - something I tended not to do since I thought it would create heat and be a negative. I like the idea of the plumbers putty around the hole....thats a great idea.
/ drilling holes #39
I have been using a hole saw, the cool thing is that I can also use a longish 1/4" pilot bit to line up holes in tubing. I drill the 1/4" pilot hole straight through from one side then use the hole saw, flip the tube and drill the opposite hole. Both holes done not ten minutes.:thumbsup:
Just wondering how thick of metal can be practically drilled with a bimetal hole saw.
/ drilling holes #40
WD40 or any lubricant oil should never be used. You want to CUT not lubricate. The only benefit would be to cool the drill bit using lube oil. The down side is that lube oil has extreme pressure additives to prevent ware.
2005 JLG 600S 4x4 Telescopic Boom lift (A59228)
2005 JLG 600S 4x4...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
2006 Lufkin FLII 45ft. 40 Ton T/A Piggyback Flatbed Trailer (A59230)
2006 Lufkin FLII...
2018 Chevrolet Traverse SUV (A60352)
2018 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
