rickyb01
I have to run 220 wiring into a root cellar I have. I will be core boring the 2" hole about 1 foot from the top. The hole will be bored into the side of building that is 8" thick poured concrete. This should eliminate a lot of hydrostatic pressure going up high on the wall. After I core bore the hole I will slide 11/2" PVC sch 40 pipe thru the hole and would like some input on sealing the area between the pvc and concrete to keep any moisture from seeping in. If I use 11/2 PVC the OD is 1.90 inches so I will have a little room. The reason I want to use PVC is I have a lot left over from a project I never did. I'm in the country so no code to speak of. I will spray paint the PVC red so that should alert anybody in the future that may own this home after me of digging.
Two questions: what would be good to apply to the PVC while sliding it in the 2" hole and working it back and forth to hopefully get a good seal?
After I run my electrical wires through the pipe what would be good to seal up the wires inside the PVC pipe? Thanks Rick
