Drill run out
/ Drill run out #1
mechanic
missouri
Any of you guys look at your drill bits after putting them in the chuck and see what looks like a little wobble when the bit is turning? This sometimes bothers me. It seems like every drill I look at even new has this problem to some extent. I have a milwaukee drill that I that was the best drill ever made and I see this somewhat in it. I tried my skil drill and seen the same thing. Is there any drill that does not have this problem? I never noticed this until I read about it on the internet. Any thoughts?
/ Drill run out #2
I noticed run-out (wobble) in drill bits on a Makita drill I had. The shaft that the chuck threads onto was bent. I straightened it enough to help, but the drill was never the same again. I'm not sure how I bent it. Probably from using electricians bits (24" long) and putting them on a lateral bind. It may also have been from using a paint-stirrer in the drill.
I've bought three new drills since then (all Makita, but Milwaukee is a very good drill too), and none of them have the problem (yet).
Do you use extra long bits (like the electrician's bits)? Do you warble out a hole to make it a bit larger by tilting the bit around in the hole? I do, but I'm a bit more cautious now since my experience with the bent shaft. Drills aren't designed to handle a lateral force on the chuck.
/ Drill run out #3
I never had that problem until about six months ago. I have had 7 or 8 like that since.
208316 (A58375)
208316 (A58375)
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63118)
2021 Gehl RT215...
2018 Ford Expedition MAX Multipurpose Vehicle (MPV), VIN # 1FMJK1KTXJEA37391 (A61165)
2018 Ford...
1984 John Deere 750 Utility Tractor (A63116)
1984 John Deere...
Magnum 4000 Hot Water Pressure Washer (A61166)
Magnum 4000 Hot...
PROPANE TANK CAGE (A62131)
PROPANE TANK CAGE...
