Drill Press Table Wanted - Generic
   / Drill Press Table Wanted - Generic
BethelHntr,
Confirming the stem on your table is 3 ¼ outside diameter and not length? Can it be punched out? Will there be enough material for me to machine it down to 1.9 inches...or insert/weld one that will fit my bracket?
Bob
Here is a pic of the stem or bottom of table
Here is the top, It has been cleaned since this pic was taken.
Can that stem be punched out? I can easily turn a stem to press fit or weld onto the table portion. Where are you located? Seeing what it takes to get that hunk of metal from your part of Seahawks Country to mine.
Bob, one of the many 12s.
   / Drill Press Table Wanted - Generic #13
It doesn't look like a 16" diameter table will fit your drill press looking at your last picture with the tape measure.
I'm in Maple Valley.
   / Drill Press Table Wanted - Generic #14
Here is one, might be too small though: Replacement Table for 12" Craftsman Drill Press 34985 Part S34985 87 | eBay
It would be easy to make a bushing to fit yours, if the table is big enough for you.
Thanks for the heads up.
I saw that on eBay too...thanks. May fabricate one at this point. Have access to a lathe and a mill. Problem is welding the stem to the table portion...I'm not a welder and don't have ready access to a welder or a person who can weld for me.
May just use your idea with this one.
Bob
You are right...it'll be a bit big. Appreciate you making the offer and taking time to work the details....
Bob
   / Drill Press Table Wanted - Generic #17
Hi Bob,
Im in Spanaway and have several welders,
I can help ya out in the welding dept if you decide to build one.
Rich
Hi Bob,
Rich
Thank you Rich...I decided to buy the one on eBay and fabricate a bushing to fit...will see what I need to do when the part arrives next week. Thanks again for the offer...hopefully I can return the favor in the future.
Bob
Tacoma
Xfaxman,
I decided to get one ready made and ordered it from eBay. Will need to wait for it to arrive to determine the size of the bushing needed.
What raw material would you use if you were to make a bushing. I'm thinking I got only about 0.4" to play with. Think a split tube design? Your thoughts?
Bob
   / Drill Press Table Wanted - Generic #20
Xfaxman,
Bob
Yep I was thinking split tube, since it clamps to keep from rotating. Here is your picture, showing where it will set.
For the bushing I would try PVC tubing first, if it doesn't work, aluminum or brass.
Keep us updated.
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
UNUSED SDLANCH SDLD25 CRAWLER DUMPER (A54756)
UNUSED SDLANCH...
2016 FORD F150XL TRUCK (A51406)
2016 FORD F150XL...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
