drill press buying
/ drill press buying #21
I bought a better than average cheap off shore floor model. It's done a pile of work but certain things broke which was an irritation. Like PLASTIC handles. I would buy a quality used (name brand) one if I had to do it again. Quality is quality and junk is junk! And the junk always looks EXACTLY like the good stuff.
BTW, I REALLY REALLY like the built in light on mine. Not something you would probably find on an older name brand one.
/ drill press buying #22
for years I had an ole “helmet head” Boice Crane C-19 40 edition.
Over the years the runout became unacceptable especially using larger drill bits so I traded it to a mason friend in exchange for some masonry work. I ended up buying an “off shore” mill and drill machine with an x-y table adjustment, variable speed, and 1/2” chuck.
It didn’t take long to realize the advantage of the table adjustment especially when drilling a number of equally spaced holes spaced in a straight line.
On the assurance of the industrial supply house where I spent my money that the quality of the imported unit was equal to Jet, Powermatic, and General I will say after several years of use, i’m A happy camper.
B. John
/ drill press buying #23
one major consideration is adjustable quill play, without being able to adjust the play in the quill, the bits used can walk all over the place.. who wants junk like that?.. believe it or not, many drill presses of the cheap variety don't have that!.. if you see on display in a store, brill the quill down, then wobble it, if it does wobble, and has no adjustment to stop that, it's Junk!..
/ drill press buying #24
I never knew that. Where are the adjustments?
/ drill press buying #25
A good used US made drill press beats any of the Asian junk available now.
I was a career manufacturing engineer. I worked with machine tools all for all of my career.
/ drill press buying #27
Interesting. I don't remember having much issue with bits walking. And the way I have abused my drill press with circle cutters and 6" hole saws would make me wonder how it stood up. Did I say, I like the built in light?
/ drill press buying #28
One drill press is not enough, I have a General Canada 340, and a Buffalo 15 and Buffalo 18. Each is better for some things, not all in the same shop though. Fully agree with a used quality North American press over anything new. I have a VFD on the General and 18 to give excellent slowspeed control.
/ drill press buying #29
I had a large old off shore 600 volt, two speed reversing drill press with x-y table. I never used it and sold it. I was always afraid it would rip my hand off for all the drilling one does by just holding something by hand. On the cheap one, the belts just slip.
Actually I need to do a bit of routing, and wish I still had the x-y table. Friends don't like doing my woodworking stuff on their Mills!
/ drill press buying #30
I still feel that the "off shore" drills biggest shortcoming is the lack of low speeds. Yes, they are are not fine tools for production work but they still suffice for my amateur jobs. :)
/ drill press buying #31
I built an extra jack shaft unit to slow down one of my drill presses.
It’s the outboard assembly on the right in the top picture.
This dropped RPM’s down to around 100.
/ drill press buying #32
That is what my dad did with his drill press and it works great.(plenty good for a garage)
CASE INTERNATIONAL 6088 RWD COMBINE (A63291)
CASE INTERNATIONAL...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2012 CHEVROLET SILVERADO 3500HD (A63569)
2012 CHEVROLET...
HIGH END MINI GOLF CART (A63569)
HIGH END MINI GOLF...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
