Drill or No Till?
/ Drill or No Till? #1
Turkeyman
Columbia, SC
JD 4720 and 5075M
We plant about 20 acres of food plots with the hopes of tripling this n the next 2 yrs. Soil ranges from black earth to clay to sandy loam. We plant rye grass, peas, rape, clover, sorghum, kale, millet, and wheat. Currently we broadcast these along with our fertilizer.
Current prep is discing several times and then planting. I would like to reduce the discing time down to one or two passes. We have looked into a 8' cultipacker but that will cost $700, and require another trip over the field.
If we go with a no till how much real world prep will we need?
How much prep will we need with a drill?
Any tipes on buying a used drill? Thanks
Thanks
/ Drill or No Till?
Thanks
/ Drill or No Till? #3
There's a million ways to go with this. All have advantages. All have DISadvantages. Doing a food plot, you're interested in getting a good stand, but not in terms of "yield" such as you would if you were commercial farming. Still and all, you're trying to get a strong healthy crop.
I've seen several "no-till" drills and planters manufactured by KASCO of Shelbyville, Indiana. I'd lean towards something like that. If you're no-tilling, you'll need a good sprayer set-up also. Then someone needs to go through certification for restricted use chemicals, get insurance for same, and know what they're doing. Cost will be at or above "conventional tillage" methods. Time and fuel are saved.
If the ground is MILD soil, consider a field cultivator instead of discing. You'll get better results from 1 pass. If you're broadcast seeding or even drilling, you won't need "the perfect" seedbed. One pass with the cultivator, seed, then drag field or run disc LIGHTLY about an inch deep.
If the object is to hold down cost, ideally, you want to do the job with what you already have, or with the smallest investment possible. Buying ONE implement is preferable to TWO. I'd look at a field cultivator if you stay with tilling. With no-till, you're basically starting over. BIG investment.
/ Drill or No Till? #4
/ Drill or No Till? #5
At my store we rent No-Till Drills as well as Brillions (for ground that has been worked). I am a Deere Dealer as well as a Great Plains Dealer, and while the Deere no-till Drills are now top notch, I rent Great Plains. Have you called all of the Dealers around you regarding renting?
Minimal prep required for no-till, close to what you are doing for a standard Drill. As far as used, watch spacing, diameter of the Discs (opening and/or closing)( as compared to new), condition of Feed Cups,, Seed Tubes, Fertilizer (and/or) Grass Seed or Native/multiple Seed boxes), bearings, condition of closing wheels, hitch and such. If you are buying out of your local area, pay attention to closing wheel width (lots of different options here). In your area I assume that Disc Drills (not Shoe) are the norm?
/ Drill or No Till? #6
/ Drill or No Till?
Thank you both for the tips. We do not know of anyone that rents these. Got a price on a no till Kasco and it was $7500 for a 6' model. A dealer told me today that my 4720 was too small to pull a 10 ft drill. Is this accurate? As you know this is a 50 hp, 4WD unit that with ballest in all 4 tires and a FEL w/ a 4 in1 weight about 7800 ( used a quarry scale). We can disc or chisel plow the earth w/ little effort, so I think we are leaning towards a drill.
Would a overseeder work or just get torn up with our roots?
/ Drill or No Till?
/ Drill or No Till? #9
I guess it all depends on what sort of "drill" you both are talking about. A more conventional, older style drill, you should be able to FLY with that tractor. A newer "no-till drill" such as a John Deere model 750, forget the idea of pulling it (in 10' version) with less than 100 HP and about 10,000lbs.
Look at "SUKUP" seeders. Less features than KASCO, but cheaper.
If I was buying a seeder to seed "tilled" soil, I'd lean towards Brillion. Several models with lots of options. GREAT reputation.
/ Drill or No Till? #10
/ Drill or No Till?
I priced 6' Sukup last year and like it, need an updated price. I will look at Brillion. I was looking at used JD drill maybe a 8300?
Thanks for all your help.
/ Drill or No Till?
/ Drill or No Till? #13
Turkeyman,
Have you contacted the Wild Turkey Federation or Pheasants Forever in your county? In my county they have a 7' no-till drill that I have used, no charge. Don't recall the brand but it worked well for timothy, brohm, alfalfa and clover. I've also used it for warm season grasses (big blue / switch) but working the ground and using a drop seeder works better for that. Pay attention to the planting depths of the seeds, it makes a difference.
I have 55 acres planted with grasses and legumes that provide cover for the wildlife. Throughout the acres are food plots planted 100' apart consisting of 2 rows grain sorghum and 2 rows corn with warm season grasses planted in between the food plot rows. I plant the sorghum and corn annually with a conventional 4-row corn/bean planter.
dsb
/ Drill or No Till? #14
Turkeyman,
dsb
/ Drill or No Till? #15
</font><font color="blue" class="small">( Turkeyman,
dsb
)</font>
That just knocked enough cobwebs outta my feeble ol' mind too make me think of another idea. Our Soil and Water Conservation District also rents (Tye and Great Plains) no-till drills. Both "pasture drills" and soybean drills.
They rent "per acre" with a minimum. I'd contact the county extention agent in your area.
/ Drill or No Till? #16
dsb
)</font>
/ Drill or No Till? #17
Good catch Farmwithjunk. The drill I used is managed by the county Soil & Water Conservation District. Was donated to them by one or both of the organizations I mentioned. In my case there was no charge, not sure if that was because I was establishing the ground as part of a conservation reserve program or not.
On another note, I get the seed for the foodplots for no charge. That comes directly from the local Pheasants Forever chapter.
dsb
/ Drill or No Till? #18
dsb
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
Blue Diamond Brush Cutter (A64126)
Blue Diamond Brush...
