Drill Bits
   / Drill Bits #31
I have the Drill Dr. 750X. Very happy with it and apparently the other mechanics on campus are too as I sharpen theirs. 1/4" on up, and the larger the better. Patience and rechecking the setting is key. Great for touch-up, not so much for when morons abuse.
I have changed the stone tho.
   / Drill Bits #32
The same but different,
Have any of you found QUALITY reverse flute dill bits and where can I find them? All I find is no-name or very large ones.
   / Drill Bits #35
Umm, didn't think of that, that puts it into perspective that is more then 1/3 of my tractor, one reason to buy a 50hp one, with cab....
   / Drill Bits #36
Wow.
It would be 1/3 the cost of my tractor!!
MoKelly
You are looking at the 'professional shop' model. Darex (same company that markets the 'Worksharp' Ken Onion sharpener sells a consumer model for around 100 bucks (and much less on sale). The consumer model don't have quite the range the shop model has nor the adjustability and precision repeatability, but for the casual user they work quite well, especially if you don't have the skill to offhand sharpen drill bits, which, in reality is a 2 handed task and something that has to be learned over time. Kind of like TIG welding where one hand is guiding the torch and the other hand is feeding the filler rod and keeping it in the gas envelope. Takes acquired co-ordination.
Offhand sharpening consists of applying the correct chip clearance and at the same time rotating the bit to obtain a sharp cutting edge and grinding the cutting edges asymmetrical with each other, all the while keeping the correct point angle.
Personally, I find offhand sharpening to be performed best on a flat plate disc versus a cylindrical grinding wheel. Much easier to develop the correct angles on a flat plate disc. Only thing you cannot do on a flat disc is relieve the heel of the web, something I always do on larger bits to facilitate chip clearance.
Learning to sharpen twist drills is class 101 when taking a machine shop or tool and die apprentiship in the trades because sharp and accurate cutting drills are paramount in any kind of machine tool work.
I'm always sharpening twist drills for my friends. None of them have a clue how to develop the proper cutting angles and chip clearance so I get them.....:) and being the nice guy I am, I do them for them.
   / Drill Bits #37
You mean a left hand drill. MSC has them as well. Cleveland Twist makes left handers and spiral flutes for softer metal high volume material removal.
   / Drill Bits #38
More in-line with the home shop is a Universal Tool and Cutter Grinder. They're in the $900-$1300 range and do a good job. But they are NOT automatic. You can't just stick a drill bit in it and sharpen it. It has to be set up for the tool/cutter you're grinding. I bought mine because I have a "machine shop" at home. I have one that uses 5C collets since I have a large drawer full of the collets already. Even this would be over the top for a handy-man DIY type. :2cents:
No home shop is going to sharpen enough drill bits to pay for a Darex. :rolleyes:
   / Drill Bits #40
:thumbsup: Thank you.
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
Wolverine Quick Hitch (A53316)
Wolverine Quick...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
