Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #1
kleinhhl
Sumerduck, VA
John Deere 1050
I recently had to split my JD 1050 tractor to replace some seals in the transmission & PTO shafts.
Although I ended up not replacing my clutch (it measured out okay)... I did buy the special tool (JDG-52) to adjust the clutch fingers for $99 (ouch)!
I've seen a few posts asking for the dimensions of the tool --- so, here you go.
Maybe you can make one out of steel or some other material in case you need to adjust your clutch.
Not sure what other tractor models (John Deere, maybe Yanmar?) that this tool will work for...
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #2
I could be wrong. but I believe the 950 may be the same.
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #3
Thanks for posting these measurements for the JDG-52. I have my JD 850 split and replacing the dual stage clutch in it and this is the tool for adjusting the clutch fingers in it. Much appreciated!
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #4
Than you! This is perfect for many of the Yanmar machines, especially the YM2500 models and higher. (y)
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #5
@kleinhhl
Thanks for posting the measurements of the JDG-52. I'm working on the clutch of my YM330 and will be making this adjusting gauge soon. (y)
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #6
Over the weekend, I transferred the measurements to a 1/8" section of Plastic/Aluminum composite material. Using a jigsaw, I cut out the larger area. I then performed more precise cuts using a bandsaw.
It worked out well. (y)
2016 Takeuchi TL8R2 Two Speed Compact Track Loader Skid Steer (A55851)
2016 Takeuchi...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 CuYd Refuse Garbage Truck (A55852)
2007 Freightliner...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: N/A Plate: (A55853)
Year: 2017 Make...
2015 GMC Acadia SUV (A55853)
2015 GMC Acadia...
John Deere 5103 (A53317)
John Deere 5103...
TAKEUCHI TL10V2 SKID STEER (A52707)
TAKEUCHI TL10V2...
