Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #1
kleinhhl
Sumerduck, VA
John Deere 1050
I recently had to split my JD 1050 tractor to replace some seals in the transmission & PTO shafts.
Although I ended up not replacing my clutch (it measured out okay)... I did buy the special tool (JDG-52) to adjust the clutch fingers for $99 (ouch)!
I've seen a few posts asking for the dimensions of the tool --- so, here you go.
Maybe you can make one out of steel or some other material in case you need to adjust your clutch.
Not sure what other tractor models (John Deere, maybe Yanmar?) that this tool will work for...
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #2
I could be wrong. but I believe the 950 may be the same.
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #3
Thanks for posting these measurements for the JDG-52. I have my JD 850 split and replacing the dual stage clutch in it and this is the tool for adjusting the clutch fingers in it. Much appreciated!
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #4
Than you! This is perfect for many of the Yanmar machines, especially the YM2500 models and higher. (y)
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #5
@kleinhhl
Thanks for posting the measurements of the JDG-52. I'm working on the clutch of my YM330 and will be making this adjusting gauge soon. (y)
   / Drawing & Measurements for JD Clutch Adjustment Tool - JDG-52 #6
Over the weekend, I transferred the measurements to a 1/8" section of Plastic/Aluminum composite material. Using a jigsaw, I cut out the larger area. I then performed more precise cuts using a bandsaw.
It worked out well. (y)
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2020 FREIGHTLINER...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
23110 (A53424)
23110 (A53424)
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
