Drawer Clamp and Plywood
   / Drawer Clamp and Plywood #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
This might interest some. I decided to add roll out drawers to our bottom kitchen cabinets. Rooting around on our knees in the back of those cabinets is getting less fun as the time goes by. There are 20 of them so I took some time to make a clamping jig for assembling them square. See photo.
The first part of the jig is the table saw fence that is just clamped in place. The second part is the piece of square tube on the right. It is squared to the fence, then held in place with two welding clamps. The third part is the piece of square tube on the left, that is movable.
The drawer is assembled and held in place by two long clamps and two short clamps. I glue and pin the front first, then turn the drawer around and glue and pin the back. It is speedy, easy, and works perfect for drawers of all different sizes.
It has been quite a long time since I last made a stack of drawers. I did not realize until I went to the cabinet supply shop to get material for the drawer bottoms, that "1/4" plywood is now 5.2mm. Which is just a hair more than 3/16". The only real 1/4" plywood they had was marine grade pine, so that is what I got. Since I had already put a 1/4" dado in the sides and front of the drawers on the table saw. The drawer sides, back and front are 11 ply baltic birch which is an honest 1/2".
I looked up 5.2mm plywood on the internet and confirmed it is the rule now. You can get router bits and slotters in 5.2mm but dado set forget it.
   / Drawer Clamp and Plywood #2
And hinges have changed too. You can still get the old style, but the newer 35mm hinges make adjustments a lot easier.
   / Drawer Clamp and Plywood #3
Nice! I'm a big fan of setting up an assembly line for multiple repeat tasks. I learned that about a million years ago from my dad. :thumbsup:
   / Drawer Clamp and Plywood #4
Nice job.
I’m in agreement. When I made our cabinets. I made as much repeatable as possible and made jigs.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
2016 Cat TL1055D Telehandler (A56435)
2016 Cat TL1055D...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
