Drawbars
/ Drawbars #1
njrqs
Queensland, Australia
Kubota L1-20 DT
Buying a drawbar for my small Kubota. The sort which is just a bar with holes in it which goes into the 2 lower links of the 3PL.
With a ball on it and trailer, will the ball try and tip rearwards when under load.
There is nothing to stop it from doing so.
Any ideas ???
/ Drawbars #2
hjrqs, you're right; you'll need something to keep it upright. I've read somewhere on the forum something about a bracket that attaches from the drawbar to the lift arm, but I haven't seen one, nor do I know where you would get it. Of course, if you can do a little welding, you should be able to make one. When I bought such a drawbar for that purpose, I also wanted the ball behind the drawbar a few inches to allow for tighter turns, so I did a little drilling, bolting, and welding to make a much cheaper, lighter version of the hitch receiver, Item #12469-C151, in Northern Tools catalog. You might look at it at http://www.northerntool.com. And right now my memory fails me, but somewhere on the forum are pictures of a much nicer one that someone else made.
I found the picture of the one McCallum made at http://www.tractorbynet.com/forumfiles/5-18855-drawbar.jpg
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 12/18/00 07:58 AM.</FONT></P>
/ Drawbars #3
I've wondered about this myself. My wife's tractor (Franklin Mint Ford Golden Jubilee) has braces that go from the drawbar to each lift arm. As precise as that model is, I'd think that may have been a Ford installed device back then.
Rob
/ Drawbars #4
Uh, your wife's tractor? How do I convince my wife she needs a her own tractor?
/ Drawbars #5
Her dad had a Golden Jubilee so I got her the model. She's now built up a small collection of them on one shelf of the curio cabinet I made for her. The downside of all this is we do occasionally fight for real tractor time /w3tcompact/icons/smile.gif
Rob
/ Drawbars #6
Bird, thanks for digging that photo out. I was just thinking about the same situation. Farm and Country sells drawbar stabilizers (slotted braces that attach to the lift arms) but when I went to access their on line catalog it was gone. When I was at the dealers Sat. they had some local made hitch recievers like the ones Northern sells for about the same price.
/ Drawbars #7
njrqs
There is a bracket called a drawbar lock. It slips on a lower third arm and then you put the multi-hole drawbar into it. TSC sell them and so does most dealers. You might only need one, If your trailer wasn't real big. I think that they sell in the $10-$12 range.
JerryG
/ Drawbars #9
How true that a picture is worth a thousand words! Thanks DFB.
Rob
/ Drawbars #11
After making a draw bar stabilizer based on info from this forum, I found out that Leinbach Equipment in Winston Salem, NC (336) 924-4115 sells a stabalizer similar to the one Northern sells. Leinbach's price is $69.50 vs roughly $200 at Northern. I was going to Winston Salem tomorrow to pick up one, but we have snow in the forecast, so it may be later in the week before I get there.
The one I made does not have a 2 inch receiver, like the one on my truck. I just mounted 2 trailer hitch balls on a draw bar; then mounted the draw bar on an A frame. Welded 2 pieces of 1" square steel to the A frame to keep the draw bar from rotating. It works well, but like someone else said, you can not turn very tight. This is why I'm getting the one from Leinbach.
I priced buying a receiver and welding it to the draw bar. In the end, the price ends up being about the same: the A frame from Agri-Supply is $28.00; the draw bar is $13.00; the 2 inch receiver is around $30.00; miscellaneous bolts to put it all together are about $12.00.
/ Drawbars
Thnaks DFB and others.
Much appreciated. So I'll try it without the stabiliser but suspect I'll need one. Although it is just for my small 6x4 box trailer and I'll see what happens !!
Gee this place is great !
Cheers
/ Drawbars #13
I use one of the drawbar locks on my B7100 and it works just fine. Since there is a TSC store in the area, I purchased the lock from them...about $17-$18 range. It's simple to install and remove. Might want to check out their website or stop by a TSC if you have one in the area.
Bob Pence
/ Drawbars #16
I wonder what happens to that if you try to raise the TPH up higher?
Rob
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
John Deere 350B Crawler Dozer (A65579)
John Deere 350B...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
JOHN DEERE 220 - 18' DISC HARROW (A64277)
JOHN DEERE 220 -...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
JOHN DEERE M15 - 15' BATWING ROTARY MOWER (A64277)
JOHN DEERE M15 -...
