Drawbar pull capability
/ Drawbar pull capability #51
Good to see he's got a shatterproof visor to protect that helmet, if the supercharger grenades.
/ Drawbar pull capability #52
Has anyone hooked up a pull gauge to their drawbar to find out the actual pull?
A TBN owned pull scale sent out to trusted people and tested in a standardized way would make a pretty neat spreadsheet on here for future generations.
That information should be available from the Nebraska tests. Drawbar pull was one of those measurements in a "standardized" way.
/ Drawbar pull capability #55
I think the working load limit of most chain is set around 1/3rd of breaking strength, so those chains would probably have a breaking strength roughly similar to the strap.
Also, I think some strap manufacturers list their "breaking strength" as the webbing alone, ignoring the weak points that are where the webbing bends tightly around a hook at either end. I say this because I've noticed the same rating listed on the same straps, in both hook end and loop end. The stitching could also be a weak area, but I suspect most good brands put enough overlap there to ensure the stitching at least exceeds the strap strength.
Did your strap fail in the middle or where it goes thru the hook? If in the middle, was there prior damage in that area?
Straps WLL is 1/3 break strength. Chain is usually 1/4 though.
/ Drawbar pull capability #58
There's always going to be variability when it is science versus opinion.
Or different manufacturing facilities and different batchs of raw materials.
/ Drawbar pull capability #59
There's no science in setting a working load limit to breaking force ratio, only considerations of risk and liability. Collect breaking force data, analyze the distribution, determine whether you want to live under a 6-sigma or 3-sigma risk regime, and name the working load limit accordingly. Statistics is math, not science!
CAT D8 (A58214)
CAT D8 (A58214)
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2025 AGT STSD10 72" Grain Drill (A60463)
2025 AGT STSD10...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SANY SY225C9C5KL EXCAVATOR (A59823)
SANY SY225C9C5KL...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
