drawbar lock
   / drawbar lock #11
Closeup shot.. took about an hour to make - taking my time /forums/images/graemlins/wink.gif
   / drawbar lock #12
   / drawbar lock #13
TSC sells cat 1 locks cor 15$ now.. but I had made 2 for my old fords before tsc was carrying them.. here's some pics:
Here's another I buzzed together in 5 minutes using a piece of bent rebar, 2 pieces if "I" beam, a large "D" bolt, and a large nut/bolt/washer.
Here's one I welded up out of 1/4" plate and a large washer.
CNH sells a 20$ "A" frame kit to turn your 11 hole drawbar into a trailer ball holder as well.. looks like this.
Here's the old ford/ferguson style:
Most of these still need a 'stay' bar to keep the 3pt lift under the centerline of the axle, for safety.
Soundguy
   / drawbar lock #14
Soundguy
   / drawbar lock #15
Soundguy,
I purchased the TSC draw bar lock and It will not fit my John Deere 2010 cat2 set up without modification so I plan on making one similar to the ones you posted. I do not use the 3pt draw bar much so am in no hurry to make the lock. Thanks for posting the photos.
Farwell
   / drawbar lock #16
Soundguy,
Farwell
   / drawbar lock #17
Soundguy, How do I get a hold of CNH , I like that A frame setup, with my hydraulic top link hooking up a wagon would be a breeze. I edit'd this post AAH CNH = Case New Holland I'm assuming, can I order the A frame from any dealer or do they have a web order service or ?
Steve
   / drawbar lock #18
Steve
   / drawbar lock #19
</font><font color="blue" class="small">( I purchased the TSC draw bar lock and It will not fit my John Deere 2010 cat2 set up )</font>
Yep.. i had to use the a-frame setup on my cat 2 tractors.
Soundguy
   / drawbar lock #20
Soundguy
Rooster Weathervane (A55853)
Rooster...
202481 (A54757)
202481 (A54757)
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
CATERPILLAR 289D3 SKID STEER (A52707)
CATERPILLAR 289D3...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
1517 (A57192)
1517 (A57192)
