3-Point Hitch draw bar
/ draw bar #1
goldman
woodstock ga.
2305 john deere
i have a john deere 2305 would like to know if i can replace the drawbar with a hydraulic one. i rember reading some were about how to do this but lost the websit. does any one know if i can do this to my tractor.
/ draw bar #2
Drawbar?:confused2:
I think you mean top link? The drawbar is used to pull wagons and such from very low under the transmission. Your 2305 does not have one, it has just the hole in the back.
You can add a HTL (hydraulic top link) to your machine, but you will need a valve to control it also, and for that you will need the Power Beyond option...
How much do you want spend?
/ draw bar #3
SLOW DOWN!
Most of the parts can come from the Surplus Center. To add a cylinders, valve, PB kit, hoses, fittings...you are looking at spending $600 easy. Do a search on these terms for some great info to get you started, this is not a "bolt on kit" for your machine, you will have to do some fabrication and design yourself.
HTL
CCM
remote
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
