Draining the 4510 radiator
/ Draining the 4510 radiator #1
yanmars
I admit I just took a quick look but I did not see a drain petcock on the radiator of the 4510. Where might it be or do you just loosen the lower radiator hose? My Yanmar has a block water jacket drain.
Ideas/suggestions. Thanks
/ Draining the 4510 radiator #2
Check 6 inches behind the oil filter. There should be a wiite plug. I think it will drain the block to. How do you like your 4510?
I had a few reservations at first as I was used to an open or non-cab tractor. I like it now as it has more horsepower than my Yanmar 336d.
The thing I dislike is the cooling system. It gets debris on the radiator, the screen looks difficult to remove, the battery and air filter block a great deal of airflow into the radiator etc. That system could have been better designed IMHO.
/ Draining the 4510 radiator #4
I had my screen out a while back. A few bolts and it kind of slid sideways a little as I remember. I seldom use the bushog so mine dosen't get plugged bad. I've had good luck with it till recently. I went to road it a couple of miles and it started to blow gray smoke and miss bad. It doesn't do this till you get it up to pto speed and put a load on it which I don't do very often. Mine has 700 hours on it. Guess I'll have to haul it the hundred miles to the dealer while its under warranty. I've really liked it though. I mostly us it for the loader.
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2015 GMC Yukon XL Denali SUV (A64557)
2015 GMC Yukon XL...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A64556)
2012 Chevrolet...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
