Draining new style fuel filter
/ Draining new style fuel filter #1
ericm979
Super Member
Southern Oregon
Branson 3725H Deere 5105
Hi guys, m 3725 has the newer clear plastic bowl type fuel filter with the priming pump. I see a bit of gunk in the bottom of the bowl and I'd like to drain it. There's a drain knob on the bottom of the bowl with a hose nipple. When I put a hose on it and loosen the knob air is sucked in around the threads but nothing comes out the hose. Is fuel supposed to come out of the hose nipple?
I can't find anything about this in the manual.
/ Draining new style fuel filter #2
Eric, I'm going off my memory which isn't very good.
I recall a filter element in the clear plastic bowl which I unscrewed (or unclipped) and emptied out. Besides the filter element that needed to be replaced, there was some water that had trapped in there which I emptied out.
I might not be answering your question but hopefully this helps.
edit: I don't recall a priming pump, maybe my tractor doesn't have one?
/ Draining new style fuel filter #3
Eric is this the fuel filter that has the red float ring in the bottom of the bowl?
Yep it's the filter with the red plastic float to indicate water.
I know I can remove the whole bowl but I'd like to just drain the bottom of the bowl as that's less of a mess.
The prime pump is the shiny metal button about 1-1.5" diameter on the top at an angle.
Another question: when you prime it do you need to open a bleed screw?
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
2013 KUBOTA SVL 90-2 SKID STEER (A65056)
2013 KUBOTA SVL...
2016 Mazda Mazda 6 Sedan (A66738)
2016 Mazda Mazda 6...
213091 (A64276)
213091 (A64276)
275/70R19.5 Tire and Wheel (A68134)
275/70R19.5 Tire...
PORTA POTTY (A68842)
