Drainage pipe leak
/ Drainage pipe leak #1
randy41
Linden VA
I have a 4" pvc drainage pipe leak at a joint between the pipe and a fitting. It has not leaked for 10 years but I think after 10 years of the washing machine bouncing around when it spins and is not balanced has caused the pipe somehow to start leaking. The joint is right under the floor that the washing machine is on (pipe is under basement ceiling). the joint is very accessable. I'm looking for a sealant kind of fix rather than a replumb kind of fix. Epoxy? Primer and pvc solvent? I was the original installer. The fitting is a y fitting with 4" coming from the WC and 2" from up the line.
/ Drainage pipe leak #2
I used some of this stuff (bought from Lowes) to patch a leaking hot water pipe and it's held up for over a year now. It's a hot, pressurized pipe so it's probably much worse conditions than a low-pressure drain pipe but it's also possible the heat helps keep it sealed.
I tried to recreate the leak with no luck. It turns out that the drain pipe if fine...it was just wet in that spot because water dripped onto it from elsewhere. the elsewhere is the washing machine. not sure what happened there but must be something to do with the washing machine's own drain pipe. after some lunch I'm gonna run it and watch the drain.
btw...both my wife and I hate this washing machine. if it died no one would cry.
2018 Frontier RC2060 (A64126)
2018 Frontier...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
CrustBuster 3800 Drill (A66285)
CrustBuster 3800...
