DRAFT CONTROL
   / DRAFT CONTROL #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I am working on several food plots for deer camp. Problem is too many rocks to plow deeply. Thought I'd use a chisel plow running 4-6 inches deep. Will I need tractor with draft control to keep plow from pulling itself deeper than that?? Since I don't yet have a tractor, do the TC45's have draft control??
   / DRAFT CONTROL
   / DRAFT CONTROL #3
</font><font color="blue" class="small">( I am working on several food plots for deer camp. Problem is too many rocks to plow deeply. Thought I'd use a chisel plow running 4-6 inches deep. Will I need tractor with draft control to keep plow from pulling itself deeper than that?? Since I don't yet have a tractor, do the TC45's have draft control?? )</font>
It is an option, installed by dealer.
Bob
   / DRAFT CONTROL #4
Bob
   / DRAFT CONTROL
Is draft control designed for the purpose I suggested with the chisel plow or other types of plows ??
   / DRAFT CONTROL
   / DRAFT CONTROL #7
I don't think the draft control mechanism cares what you hook on the 3 point, it will still work.
   / DRAFT CONTROL #8
   / DRAFT CONTROL #9
</font><font color="blue" class="small">( Is draft control designed for the purpose I suggested with the chisel plow or other types of plows ?? )</font>
My limited understanding of draft control indicates it is designed to keep the draft constant on any ground engaging implement. Plows are ground engaging implements. When engaged in the ground, it requires draft to pull it. Draft (amount of force on the implement) can be kept constant with draft control. Too much draft, implement is raised out of the ground, returning the draft to the amount chosen by you, the user.
Bob
   / DRAFT CONTROL #10
Bob
Polaris Side by Side (A50324)
Polaris Side by...
Hydrema 912HM Haul Truck (A52384)
Hydrema 912HM Haul...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
