Draft Control?
/ Draft Control? #1
VTHartford
What is draft control as it relates to a tractor?
Bill
/ Draft Control? #2
It varies by tractor brand, tractor size, and tractor age.
Would help to know which tractor you want information about, or which task you want to perform that you think draft control is the answer.
A search on 'draft control' should give you a lot of good information and interesting reading.
/ Draft Control? #3
Harry Ferguson "invented" the 3 point hitch. Part of the "value" in his invention was the ability of a smaller, lighter, lower horsepower tractor to do the work of something bigger.
Back then, almost every tractor spent a fair amount of time with a plow mounted on it. The load (or resistance) a plow exerts on a tractor is called "draft". It's effected by the depth at which the plow is operated. Draft control is the tractors ability to sense increasing or DECREASING draft loads as the tractor moves along. It moves the plow up or down (ever-so-slight sometimes) to regulate that draft load. As the plow is lifted slightly in tough going, it pulls down on the rear wheels, increasing traction through the tough plowing. After the tractor passes through the tough spot, and the draft load lessens, the plow will return to it's pre-set depth.
Draft control is of very limited use in anything but tillage. (i.e. moldboard plow, chisel plow, field cultivator, ect....)
New Holland 851 Round Baler (A66408)
New Holland 851...
LOOK! (A63111)
LOOK! (A63111)
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
