Draft Control on Kubota GrandL series
/ Draft Control on Kubota GrandL series #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I was looking at the GrandL series catalog today. I noticed that all of the GrandL series, from L3130 to the top of the line L5030 all have draft control as an option. Now, I am curious as to why draft control is an option on all the GrandL series? I thought draft control was used for ground engaging implements like a 2 bottom plow. Can a 32 HP tractor pull a ground engaging implement like a bottom plow? I thought bottom plows took a lot of power. Is 32 HP enough power???
Bob
/ Draft Control on Kubota GrandL series #3
Yes, 32HP is enough, Doc Bob, but a few other factors have to be right as well. The weight has to be there and so do R1 tires and good gearing.
As I recall the old JD40 with a 100 cu. in. 2 cylinder gas engine of around 25HP was rated at 2-14s. It didn't pull 'em very fast though. The small Fords would handle a 2-bottom plow as well. My 3 cylinder Ford 2000 does a fair job with 2 bottoms. It's biggest problem is lack of weight on the rear tires and a low gear that's a bit fast....its 35HP is plenty, however. I think with good gearing and filled rears, an 8N or 2N would do OK as well. Keep in mind, these are all 2WD tractors.
A Grand L, regardless of HP, has the weight (especially with the rear tires filled) and the gearing. Should be able to handle 2 bottoms with ease. I'd expect the L4330s and above to be capable of 3 bottoms. 15HP per bottom is a conservative rule of thumb...if everthing else is right. A B3030 wouldn't be a good choice, however.
Bob
</font><font color="blue" class="small">( Well, it depends... try this site for details. )</font>
Nice chart. I am struggling with understanding it and applying it. Any help???
Bob
I tried a sample calculation.
Moldboard
4.5 mph x 2.1 x 800 / 375=20.16 HP for PTO.
So, one bottom plow would take 20 PTO HP?
Bob
PS Why is sandy soil 2.1 and form soil 1.5? I woulld have thought it would have been the other way around?
/ Draft Control on Kubota GrandL series #6
I have a Kubota L3430 and a King Kutter Two Bottom 14" Plow. I can pull it no problem in low range, four wheel drive at about 3 - 4 mph.
ksmmoto
</font><font color="blue" class="small">( I have a Kubota L3430 and a King Kutter Two Bottom 14" Plow. I can pull it no problem in low range, four wheel drive at about 3 - 4 mph.
ksmmoto )</font>
Nice to hear from someone who is actaully using it! Do you have draft control?
Bob
/ Draft Control on Kubota GrandL series #8
No, I don't have draft control. I haven't plowed a very large area yet, so I'm not sure if it is really needed.
In fact, I believe having HST will help with the plowing as I can letup slightly if the plow hits a hard spot and the tractor will keep pulling strong.
I know most people will say that gear is best for field work and they may well be right for large fields. But I may only do three acres at the most at one time.
ksmmoto
ksmmoto )</font>
What kind of soil? Virgin? Sand? Clay?
Bob
/ Draft Control on Kubota GrandL series #10
I have been pulling a 2 bt plow with a 45 hp tractor and it has to work but I am plowing ground that hasn't been turned over in 25 years and the sod is thick and heavy. I think soil conditions mean a lot and also how you have the plow set up. My tractor has draft control as a standard feature and that's one of the reasons I bought it.
/ Draft Control on Kubota GrandL series #11
Soil conditions do make a lot of difference. Another thing that makes a lot of difference is the way the plow is made. I haven’t seen a plow made in years that was worth a hoot. A moldboard plow is one of the things that were truly better years ago.
</font><font color="blue" class="small">( I have been pulling a 2 bt plow with a 45 hp tractor and it has to work but I am plowing ground that hasn't been turned over in 25 years and the sod is thick and heavy. I think soil conditions mean a lot and also how you have the plow set up. My tractor has draft control as a standard feature and that's one of the reasons I bought it. )</font>
I can assume that you are glad you have draft control? Has it worked as expected?
Bob
</font><font color="blue" class="small">( Soil conditions do make a lot of difference. Another thing that makes a lot of difference is the way the plow is made. I haven’t seen a plow made in years that was worth a hoot. A moldboard plow is one of the things that were truly better years ago. )</font>
Any good oldies, 1 and or 2 bottom plows that i should look for??
Bob
/ Draft Control on Kubota GrandL series #14
The ones that I have either used or have seen used that worked the best were old Fords, Ferguson’s or Masseys. Look at Ken Sweets Internet site. He has lots of plows and you can get an idea of prices for them. If you go to farm auctions you can sometimes get a good deal if the bidders don't get carried away.
</font><font color="blue" class="small">( The ones that I have either used or have seen used that worked the best were old Fords, Ferguson’s or Masseys. Look at Ken Sweets Internet site. He has lots of plows and you can get an idea of prices for them. If you go to farm auctions you can sometimes get a good deal if the bidders don't get carried away. )</font>
Do you have a link for Ken Sweet's site?
Bob
/ Draft Control on Kubota GrandL series #18
Bob <font color="blue"> </font>
Seems to work all right. I still find myself fooling with the position control a good bit. I am not out plowing huge acerage, so far 6 food plots and 4 gardens.
/ Draft Control on Kubota GrandL series #19
Interesting post. hey what if you got your bota without the draft control. Can you have a dealer install it? How much do you think it will cost? I have some plowing to do this fall and did not get the draft control. Didn't think I would need it. Now I am not so sure. Any help?
JIM /forums/images/graemlins/cool.gif
</font><font color="blue" class="small">( Interesting post. hey what if you got your bota without the draft control. Can you have a dealer install it? How much do you think it will cost? I have some plowing to do this fall and did not get the draft control. Didn't think I would need it. Now I am not so sure. Any help?
JIM /forums/images/graemlins/cool.gif )</font>
I think it is a dealer installed acessory.
Bob
PS It is for NH
2022 EZ-GO ELITE...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
Trimble EZ Guide 500 Monitor (A63117)
Trimble EZ Guide...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
Location (A63117)
Location (A63117)
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
