Draft - 4110
/ Draft - 4110 #1
BobF
I've never used the draft control on my 4110 or any other tractor.
When I get ready to plow, I need to know exactly how to use this thing. So, the plow is hooked up and the pin on the top link connector has been moved to the slotted position.
Now what?
Do I still raise/lower with the pos lever, controlling draft response with the draft lever, or is this wrong?
BTW, I'd like to talk to the engineer that designed the pin system for the top link - I'll never understand why these things are designed to require sledge hammers for setup/operation.
A step-by-step on draft mode with a plow would be great.
/ Draft - 4110 #2
Start plowing with the position and draft in the down position. The plow will pull down into the ground, then raise the draft control until the desired depth is reached and leave the draft lever at that position. Use the position control to raise and lower the plow at the end of the field. If you need additional adjustment on the plowing depth use the draft control for that. I hope I explained that well enough.
/ Draft - 4110
Thanks - sounds simple enough and pretty much what I was thinking.
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
JCB 3TS-8T TELESKID SKID STEER (A65053)
JCB 3TS-8T...
2154262019 FAE UMLV SSL- 150VT HYD MULCHING HEAD (A65053)
2154262019 FAE...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A67148)
2019 FREIGHTLINER...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
