Draft - 4110
/ Draft - 4110 #1
BobF
I've never used the draft control on my 4110 or any other tractor.
When I get ready to plow, I need to know exactly how to use this thing. So, the plow is hooked up and the pin on the top link connector has been moved to the slotted position.
Now what?
Do I still raise/lower with the pos lever, controlling draft response with the draft lever, or is this wrong?
BTW, I'd like to talk to the engineer that designed the pin system for the top link - I'll never understand why these things are designed to require sledge hammers for setup/operation.
A step-by-step on draft mode with a plow would be great.
/ Draft - 4110 #2
Start plowing with the position and draft in the down position. The plow will pull down into the ground, then raise the draft control until the desired depth is reached and leave the draft lever at that position. Use the position control to raise and lower the plow at the end of the field. If you need additional adjustment on the plowing depth use the draft control for that. I hope I explained that well enough.
/ Draft - 4110
Thanks - sounds simple enough and pretty much what I was thinking.
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
2020 Bobcat S450 Compact Wheel Loader Skid Steer (A61572)
2020 Bobcat S450...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
2020 Autocar Xpeditor T/A New Way 31ASL 31Yd Side Loader Garbage Truck (A61573)
2020 Autocar...
