Draft - 4110
   / Draft - 4110 #1
BobF
Bronze Member
I've never used the draft control on my 4110 or any other tractor.
When I get ready to plow, I need to know exactly how to use this thing. So, the plow is hooked up and the pin on the top link connector has been moved to the slotted position.
Now what?
Do I still raise/lower with the pos lever, controlling draft response with the draft lever, or is this wrong?
BTW, I'd like to talk to the engineer that designed the pin system for the top link - I'll never understand why these things are designed to require sledge hammers for setup/operation.
A step-by-step on draft mode with a plow would be great.
   / Draft - 4110 #2
Start plowing with the position and draft in the down position. The plow will pull down into the ground, then raise the draft control until the desired depth is reached and leave the draft lever at that position. Use the position control to raise and lower the plow at the end of the field. If you need additional adjustment on the plowing depth use the draft control for that. I hope I explained that well enough.
   / Draft - 4110
Thanks - sounds simple enough and pretty much what I was thinking.
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
