DR Power Grade Hydraulic Retrofit
   / DR Power Grade Hydraulic Retrofit #11
I was amazed at how well it groomed the gravel turn around. Mine is just the 4' version. For giggles I used an hunk of electrical strut for some adjustablity in place of the actuator and gave it a go. It could be worth bracketing up something for the three point I suppose for ease of maneuvering. Right now I just have a standard blade.
The fittings finally arrived today. Tomorrow I'll install them and post the final results!
The fittings arrived yesterday and I installed them this morning. It works! The rate of travel is MUCH faster than before - it almost jumps off the ground it moves so quickly. I suppose you could put some kind of flow control on it but I find its easy enough to push the lever down part way to slow down the flow of fluid to the cylinder. I'll try it on the road in the spring and let y'all know how it works.
   / DR Power Grade Hydraulic Retrofit #14
Tada! Thanks for the update.
Total cost was about $165. The electric actuator from DR (PN 38478) is $150 + about $20 S&H.
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
2008 International 4300 Water Truck, VIN # 1HTMMAAN58J687362 (A57453)
2008 International...
2851 (A58376)
2851 (A58376)
REDDICK 300 GALLON SPRAYER (A58374)
REDDICK 300 GALLON...
