Appreciate the detailed responses.
Is there any advantage of DOC vs DPF? either maintenance, cost, downtime etc? You mention the doc will be higher heat in the exhaust all the time, but it seems like the doc doesn't need to be replaced or cleaned like the DPF?
Also is there any easy way to search for T4 interim tractors? I'm assuming there are certain model years that escaped the emissions requirements.
EDIT: I should add I'm specifically staying below the 75hp limit to eliminate DEF. My thought process is the fewer emissions systems, the less stuff that can break increasing my overall cost.
Let's see.... Interim Tier 4 came in different years for different engine sizes - I believe that the 50 to 100 hp range was about 2007 to 2014. Someone can check me on that but it is easy enough to look up the chart. Remember, the Tier 4 interim did have some emission control systems. For example most had a fairly complex EGR system. And those are not starting to need some attention.
If you want back to before any emissions control at all you may have to step back to pre-Tier 4 interim. The Tier 2 & Tier 3 manchines had almost none or almost no emissions controls.
FOR A CHART, GO TO:
So it's not all simple.
I have one DEF diesel - I love it. It doesn't have any fumes at all. No super hot exhaust, no soot, and no odor. If I get to choose, my next tractor will certainly have DEF too. All the newer John Deere 310 models have it. It's a very simple system with minimum parts to wear, but does add another fluid which increases the cost - in my case about ten cents a gallon.
The big advantage to DEF isn't something you notice until you have one - and it's a personal advantage that doesn't make a difference to everyone. It is that unlike DOC and DPF which need to be run at high RPM most of the time, the DEF machine can idle along like the old fashioned diesels when it isn't working hard. I'm used to that, and used to the way those old pre Tier IV diesels would idle along until the governor would rev them up to meet a heavy load ... and then automatically go back to a lower RPM when the load isn't there. I like a motor that does that.
It's my land, I grew up with diesels that worked that way, and its relaxing to me.
As a side benefit, I think that an engine worked at variable RPM will last longer - though in fairness that's still a debate and unproven. One thing that isn't debatable is that a machine that automatically idles down sure uses a less fuel. Half the time or more it's just idling. When it does rev up, it rarely goes over about half throttle. Consider that in your overall cost.
When working, I set the throttle for would be called a "fast idle" - about 1200 RPM - and let the governor & auto-throttle take care of the rest. I can always over-ride it with the throttle. But frankly I rarely find a need for full throttle horsepower. So the 60 horse tractor probably runs at about 30 hp most of the time, and the 90 hp not much more. Backing off to half throttle still gets the work done, less expensively, more enjoyably - but you have to have either a pre-tier IV and put up with the smoke, or move up to DEF if you want good idle capability.
Good Luck, rScotty
