DPF Regen
/ DPF Regen #1
Oiltech
La
Kubota L3540HSTC, M7060HDC-12, ZD331-72, Bobcat E42
I read the manual on my M7060 and I think I have a basic understanding of how it works and when to perform the Regen. Any of you have any experience with this?
/ DPF Regen #2
If it is like my M135GX it's almost a non-issue except that it takes about 15 minutes for a regen so I plan ahead to make sure I am doing something rather than waste fuel doing a static regen. I've never had mine regen while doing something easy like stacking bales so I don't know how it handles a job like that. My regens have been chopping hay, baling hay, plowing and disking., all under a pretty good load except for corners which did not cause me to change my method. I do set one of the lines on my display to DPF %plugged so I can predict the event. Once it is regenerating, however, I only know it is happening by the indicator light, the flashing %plugged display and a slight change in exhaust note. A habit I have is to press auto whenever I start so I don't forget about it when a regen is due but I did forget one day. I noticed the regen was due when a light started flashing so I punched the auto button and the regen started like normal.
/ DPF Regen
Thanks for the reply, on an average how many hours of engine time do you think the regen occurs?
/ DPF Regen #4
I have an SVL90 that has the DPF, I only have 150 hrs on it and its only gone into regen mode twice. If you lug your machine or let it idle a lot it will go into regen mode more often. I do have the ability to postpone it if I'm not running hard or if I'm about to stop working, other than that, when it is doing it I don't even notice it.
/ DPF Regen
Thanks, good information
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
2006 Flori Off Road Dump Truck DF40 (A65579)
2006 Flori Off...
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
240 Massey Ferguson Tractor (A61165)
240 Massey...
Plasma Cutter (A66408)
