If it is like my M135GX it's almost a non-issue except that it takes about 15 minutes for a regen so I plan ahead to make sure I am doing something rather than waste fuel doing a static regen. I've never had mine regen while doing something easy like stacking bales so I don't know how it handles a job like that. My regens have been chopping hay, baling hay, plowing and disking., all under a pretty good load except for corners which did not cause me to change my method. I do set one of the lines on my display to DPF %plugged so I can predict the event. Once it is regenerating, however, I only know it is happening by the indicator light, the flashing %plugged display and a slight change in exhaust note. A habit I have is to press auto whenever I start so I don't forget about it when a regen is due but I did forget one day. I noticed the regen was due when a light started flashing so I punched the auto button and the regen started like normal.
