DPF and Emission Controls vs Models
   / DPF and Emission Controls vs Models #41
The often repeated idea that these systems are trouble free is so false that it needs to be called out as an outright deception. Anyone who has been writing these things for the long term knows that they are extremely problematic and the only “reliable” thing about them is that you can count on them failing within 5-7 years. Repairs are not affordable and many desire to bypass the system when faced with the cost. My Kubota regens every 16 hours or so, I run it at very high rpm.
I have a 2012 F250 diesel engine with almost 200k miles on it. It has proven to be very reliable, but the repairs I've had to make are all with the DPF system which is in the Thousands of $$$$, and days of delays to get parts and the repair time. I've just recently had to replace the DEF heater at a cost of ~$1500. And I'm in Texas and it doesn't get cold enough to freeze DEF (11* F to freeze it), so why do I need it? I had it fixed because that error would mask any other faults that may actually be a problem.
The other non-DPF repair was a $60 vacuum solenoid that I replaced myself.
   / DPF and Emission Controls vs Models #42
Stricter Tier IV off-road diesel engine emission reduction standards phased in dealer tractor inventory during 2009 - 2012, impacting tractor prices.
Tier IV emission standards require tractor manufacturers to add or revise pollution reduction technology on new tractors generating over 19 kW power = 25.4794 horsepower.
What about BX2670 and 2670-1 for example that are close to that threshold?
Some manufactures can meet Tier IV requirements without a Diesel Particulate Fillter on low engine displacement, relatively high rpm engines powering ~2,000~ pound bare weight tractors up to 27 horsepower.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower.
DPF is used by the majority of tractor manufactures for emissions control on OVER 24.4794 horsepower tractors.
Tier IV technology complicates the engine and exhaust package and is a significant cost factor. Tier IV technology tractor emit only about 1% of the pollutants emitted by a pre-Tier IV tractor.
Diesel Particulate Filter (DPF) captures exhaust particulates (soot) in a ceramic matrix. When tractor engine runs sufficiently hot, accumulated particulates burn off periodically without operator intervention. If engine is not run continuously hot long enough to burn off particulates, diesel soot accumulates in the matrix. Once heavy soot accumulates in DPF the tractor forces soot clearance with the tractor parked and throttle open to about 2,200 rpm for about sixteen minutes, which makes the DPF REALLY HOT to burn off all accumulated soot. Burning off accumulated soot, either during operation or parked is called REGENERATION.
Regeneration is an infrequent DPF event with my Kubota three cylinder, 37-horsepower engine. Generally once every sixty engine hours. (Very consistent in Florida due to warm weather.)
60 hours X 60 minutes = 3,600 minutes.
16 regeneration minutes /3,600 = .00444 = 4/10s of 1% of engine time is consumed during parked regeneration.
Fuel cost for sixteen minute parked regeneration @ 2,200 rpm ~~$1.00.
Forty percent of my regenerations occur during operation, sixty percent parked.
The average residential tractor operates eighty engine hours per year, according to industry surveys.
3,000 hours DPF Life / 80 hours = 37.5 years of residential use prior to DPF replacement.
Diesel Particulate Filter supersedes tractor muffler.
At some point in time DPF needs to be replaced.
At some point in time tractors with mufflers need the muffler replaced.
But mufflers are much cheaper. Ash is the DPF killer which is the reason low ash engine oil. Testing shows that all Diesel engines in the U.S. before DPF totaled 5% of the particulates and China produced 30% of the particulates found in this country. Next thing is to figure out how much pollution is made manufacturing and replacing all this equipment, including mining, and trucking it around and disposing of said equipment.
   / DPF and Emission Controls vs Models #43
When looking at diesel problems, I'm not sure how much faith to put in Ford's diesel troubles. We've had three recent Ford truck diesels. Two of them were more trouble than they were worth - literally.....during the life of the truck, the diesels cost more to fix than the truck cost new.
Of the tractor diesels we've had, none have had engine problems anything like the Ford.
Our Japanese and German diesels have been trouble free.
For us, the Ford diesel is not the standard, it is the oddball.
rScotty
In the 1960's I travelled to New York, Los Angeles and San Francisco regularly on business. The air was so polluted I was ill by the end of almost every trip. Now there are, I am guessing, twice as many vehicles on the road and when fire smoke is not bad, one can breathe reasonably well.
I could not disagree with you more.
Tier IV technology tractors emit only about 1% of the cancer causing diesel soot emitted by a pre-Tier IV tractors.
So Jeff, your really believe that the air got clearer and we breathe better because the EPA went crazy stupid turning the screws down on VW diesels and went after tractors which are are a tiny, tiny part of overall air pollution?
I could not disagree with you more...to coin a phrase.
   / DPF and Emission Controls vs Models #45
What I got from Jeff's message had to do with the air being much worse back before the the gov't put the screws down on pollution of all forms. Mostly industrial smokestack industries, but yes - also vehicles of all forms. And it worked. That is what Jess is saying. The air is lots cleaner. Everyone knows that.
He is simply giving credit where credit is due.
Speaking strictly for myself now, I am disappointed that we waited until a lot of smaller industries got hurt. Small farms, small diesels, and many others.... mostly the smaller folk. Like you and me. But we understood at the time that big city smog had become a real emergency. Luckily we had a government that was even bigger than big business at the time.
As a society we tolerate a lot of things in an emergency. It's one of our country's strengths. But maybe next time we can use our brains to fix things before the emergency happens. That would be worth doing.
rScotty
   / DPF and Emission Controls vs Models #46
rScotty
I remember brown smoggy skies in the 1960-70s. And there was often pollution alerts warning people with respiratory problems to stay indoors. We also witnessed acid rain killing forests and rivers that caught fire. Nixon’s clean air and water acts made a difference over so many years. I imagine many people posting are too young to remember those days.
I am 80 in Sept. Not too young anymore. I recall the Viet Nam war protesters having no more war to march against or protest about in 1975 when Saigon fell. I recall very vividly at the time thinking it was great to have a universally good "cause" to work on like cleaning up the USA and take the place of rancor. Environmental, roadsides, water, air, etc. Something all of us could support while the activists of the day could turn their energies to the positive. Like nearly every extreme you can point to it started out with good intentions.
   / DPF and Emission Controls vs Models #48
Isn't that always the problem?... What do you do with the people on the front line once the emergency is over? What about the agency they worked for?
We created the emergency and the response. Part of the price of victory was creating a bunch of "true believers". Does it matter if you call them military veterans or environmental zealots?
Now how to tell them that their job is no longer needed? You'd think they would be happy to have done and be free to do something else. Most seem to be, but there will always be frantics who aren't.
rScotty
   / DPF and Emission Controls vs Models #49
And thank God they are now going after coal fire ovens in NYC!!! Ridding those historic Italian pizza restaurants of these dangerous cooking devices will surely save the planet! Unbelievable….
What’s next?
Mike
   / DPF and Emission Controls vs Models #50
rScotty
I think the air got cleaner when all the factories and foundries moved to China and India.
When it comes to fines for the Diesel manufacturers that’s just government taxing indirectly. All the makers had to pay fines at some point. That makes it obvious.
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
23105 (A56859)
23105 (A56859)
Atlas Sound Ceiling Speakers (A56860)
Atlas Sound...
Tractor Tires and Rims (A56860)
Tractor Tires and...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
