Downsizing
/ Downsizing #1
PLOWER
Wisconsin
JD 4710 JD Lt133 JD 345
How do I down size a Picture to 200000 bytes. The ones on my computer are all 300000. Thanks
Cliff
/ Downsizing #2
Just lay off at least 100,000 of your pixels. If the government doesn't jump in and bail them out, you should be just fine. /w3tcompact/icons/laugh.gif
But seriously, you just need one of many software programs that can change the size and/or compression quality of your picts. I'm an Adobe Photoshop bigot, plus I'm on a Mac, so I probably can't name any specific programs for you. Someone should be able to name some free, downloadable software that will suit you just fine.
Too bad there aren't free, downloadable 3-pt implements, too. /w3tcompact/icons/crazy.gif
/ Downsizing
Harv thanks,
I was just wondering, I have a few saved on my computer from some of my friends that are cool. When you buy a digital camera, doesn't it come with a program? Thanks,
Cliff
<P ID="edit"><FONT SIZE=-1>Edited by PLOWER on 10/08/01 06:43 PM (server time).</FONT></P>
/ Downsizing #4
Cliff--
You'll undoubtedly get more knowledgeable advice from some of the computer heavies on TBN, but I think the only way to get large-file-size pictures to a postable size is to open them in a photo editor and then "save as" a copy with different parameters. In MS PictureIt, which is definitely Photoediting for Dummies, click on "options" and you can dumb the picture down (the smaller the numbers the smaller the file). It also has a "save for the web" option which turns an 800k picture into a 24k picture which is still intelligible onscreen. In other editors the process is more complicated, but in the handful that I've used it always involves file/save functions. If you don't have an editor, I'm sure there is a shareware/freeware way to do this that someone can refer you to. Good luck!
Rick
/ Downsizing #5
Your photo program should have a picture resize option, if you make the picture physically smaller it then takes up less space. I do this all the time with no problems using Photostudio or MGI Photo suite.
<font color=blue>Robert Turk Jr.</font color=blue>
<font color=blue>Whitetail Splendor Deer Farms</font color=blue>
<font color=blue>Silver Creek, NY</font color=blue>
/ Downsizing
I have no photo software. I need to get one. Whne you buy a digital camera does it come with a software?thanks,
Cliff
/ Downsizing #7
<font color=blue>When you buy a digital camera does it come with a software?</font color=blue>
Mine did. I actually have 2 or 3 tools to reduce the size of a picture. The one I seem to use the most is called Paint Shop Pro (AKA PSP), although it's certainly not the only one. It gives you the ability to re-size a photo, and also allows you to alter the compression ratio. I usually just resize to 640x480 (or thereabouts), and set the compression to 30 (PSP allows this to be set from 1 (no compression) to 100 (maximum compression)).
You can download a demo version of PSP from here.
The GlueGuy
/ Downsizing
GlueGuy,
Where is a good place to get a camera? I was looking at Wal-Mart a while back. I think I will pick one up soon. thanks,
Cliff
I'm moving up to a 5205!
/ Downsizing #9
/ Downsizing
Scruffy,
Thanks for the link, but I think I'm just going to go get a camera. I think it is time./w3tcompact/icons/smile.gifThanks,
Cliff
/ Downsizing #11
Re: Digital Camera
Cliff,
I ordered my camera online from Abes of Maine. But before you can even start to order a camera, you need to determine what camera to buy. One thing you definitely want is a USB connection. Size, features, price, etc. will all be personal decisions.
Check out DPreview.com for an excellent resource to pinpoint the camera(s) that would fit your needs.
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
/ Downsizing
Re: Digital Camera
Dave,
I will check that out. Thanks,
Cliff
/ Downsizing #13
Plower, I have an Olympus D-460Zoom camera and it came with its own software. One of the options is to "resize" so you can cut a picture down to any size you want.
Bird
/ Downsizing #14
Rick, I have Microsoft Picture It! and it looks like a real fine program if it worked. My instructions also say to click on "options" 'cept there ain't none. My menu bar at the top only has "File" and "Help". I haven't figured that one out yet.
Bird
/ Downsizing #15
Bird,
You first need to load a file. Once loaded, you get more menu items. The Options... selection is then under the View Menu.
Regards,
Fallston, Maryland
/ Downsizing #16
Thanks, Dave, I'll have to try to different things with files. I had opened a blank page to try to make a collage and then opened 3 pictures I wanted, but never found anything else on the menu bar.
Bird
/ Downsizing #17
Bird,
My wife has MS-Picture It! on her PC. I have not used it, but I did run it to find the answer to your Options question.
I, on the other hand, use Paint Shop Pro (same as GlueGuy does). You can go to their website and download a FREE demo version that will work for 30 days. After that you would have to buy it if you want to continue using it. It is a very comprehensive program, so you may be alittle over whelmed at first. I have been using it for many years now. I bought my wife the Paint Shop Pro book from Barnes and Noble which is a much better teacher than I am. She is starting to get the hang of it.
As long as we are discussing software and pictures. I highly recommend the Ulead Photo Explorer Pro for viewing pictures you take with a digital camera. You can also get a FREE demo version from their website. It allows you to pull the pictures off your digital camera, create slide shows, print images, auto rename of file(s), describe your pictures, and many other features.
Regards,
Fallston, Maryland
/ Downsizing #18
Bird--
Given your new computer (at which you have become, by now, truly expert; right?!), I assume you have "PictureIt! 2000" or '99. Once you get a picture open by doing either file/open or clicking on one of the options on the "home page" which PictureIt loads, then you can either do "file/save as" at which point you get "options" as an option, or you can right-click and get a pretty complete menu which includes a save-as sub-menu. The right-click gives you a lot of choices which the menu bar does not. To do your collage, do "file/new blank picture" then "done" (at the bottom left) then "add something" then picture" then drill up or down through the C: drive directory structure to find a picture, add it, do it again, etc. In classic Microsoft fashion, IMHO, the program is not especially intuitive, but if you're not one of the lucky stiffs with Photoshop, it's not too bad once you get used to its navigation foibles. Is the collage for us?
Rick
/ Downsizing #19
I like to use a program called Irfanview. It is free, and is a pretty good graphics viewer/editor. In many of these programs, the option you are looking for is called resize / resample. The way to make a picture smaller is to either make it a smaller size (the viewable area), use a smaller color depth (the number of different colors each pixel could be) or to use a higher compression. You should be able to get your pictures down to around 80k with a size of 640X480 and a JPG compression of about 7 (on a scale of one to ten, ten being the largest file size, and one being the smallest). You can download the Irfanview program from the following link Irfanview
rf33
/w3tcompact/icons/wink.gif
/ Downsizing #20
Re: Digital Camera
You only want a USB camera, if you have USB port, AN OS that supports USB (NT does not)
Gary.
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
2019 Kia Sorento AWD SUV (A61569)
2019 Kia Sorento...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
Truck Tractor (A61568)
