Downloading photo test
/ Downloading photo test #1
srs
Veteran Member
Jarrettsville Maryland
Kubota B3030 HSDC
photo test
/ Downloading photo test #4
Cause you shuda done it like this: cleanup, crop and post.
/ Downloading photo test #5
You need to post more pics of the tractor for practice. Because your not quite their yet...you were'nt downloading, you were "uploading" to TBN. now lets see more tractor pics.:D
/ Downloading photo test #8
Magic beans... :)
Read the post above yours...
WayneB said:
You are doing just fine, and nice looking shop area too!
Thanks Wayne! I'm trying, but I know I have a lot of reading to do to figure this photo stuff out, but slowly and surely I'll get there, at least I hope so. As far as the shop it's a Morton building 30 X 45. It's a mess right now as I'm trying to install some OSB to cover the insulation. I already installed some OSB in the rear of the building and on the side wall you can still see the plastic (vapor barrier) covering the insulation. It's one of those fun projects that will take some time to complete.
/ Downloading photo test #13
Hi Stanley, one thing is for sure we would all love to have a Morton building to store stuff in and play! My wood shop is 24 x 32 and when we first set it up I figured I would never need all the space and spread things out, as time went on I keep moving things closer and closer and now there is no room.
As for the pictures you might want to establish an account (it's free) with something like photobucket to store your pictures. Image hosting, free photo sharing & video sharing at Photobucket
You will be able to up load pictures and then store them there. They also provide you with the ability to work with the pictures and be able to pull them into a forum thread either as a drop in type picture or a link to the location on line. You will also be able to re-size the image to make it fit nicely on the forum and it will be easier for the people reading / looking at the pictures.
example
same picture with a link
http://i176.photobucket.com/albums/w198/wayneB_album/DSCN0229.jpg
Once you get the hang of it you will see it is pretty easy to deal with.
Regards, Wayne
srs said:
Wayne, thank you very much sir.
Here is a photo showing the rear of the B1550 using Photobucket and superb instructions from "GRRRR", Jimbrown, and WayneB. No I did not edit it. Thanks guys! Slow but sure.
/ Downloading photo test #17
This is a photo posting test.
This is my grandpap trying out my tractor last summer. He is used to something a little bigger. He has a John Deere 310 backhoe.
Although he is 85 years old he always looks for an excuse to be on his backhoe...just like me.
/ Downloading photo test #18
Nice pictures and I only can hope at 85 to be able to climb up onto my tractor, heck who knows by then I might have a brand new one!
/ Downloading photo test #20
Not bad, but it could be better...
In photobucket, (on the photo, not the slideshow) put your mouse curser inside of the photo and press your right mouse button. That should open up a menu box. At the bottom of that menu, click on "properties". That will open up another box. On the third line down, you should see, "Address: (URL)" Capture that address and post that into your message box. Like this:
http://i283.photobucket.com/albums/kk286/lb59/100_2300.jpg
If you don't know how to capture the address (read on...)
Put your mouse curser over the text (starting with "http") then press (and hold down) your left mouse button and drag your mouse curser to the right AND down a little (just in case the address wrapped around to the next line or two). When all the text is highlighted, release the left mouse button. The text should still be highlighted. Move your curser back on top of the highlight text, and press (and release) the Right mouse button... which should open a little menu box. Look for and click on "copy". Then you can go to tractorbynet and paste the URL address.
