Down again
/ Down again #1
Rolando
Platinum Member
Northcentral Florida
Bobcat Toolcat High Flow Turbo C-series
After three pumps without fixing the problem insufficient hydraulic flow to run my mower, they finally figured out that the problem was some restrictor valve that was stuck. But now after about two weeks of use, the engine will run but I'm getting the "!" General Warning light with the 50-41 code: "Rear PWM Error OFF".
Hydraulics and Auxiliary Hydraulics will work, but it won't respond to the Drive Pedal either in Forward or Reverse so I can't move it at all.
Of course this has to happen on a Saturday morning when I had work planned for the whole weekend. Does PWM stand for Pulse-width Modulation? Is this a motor control issue? Does anybody know what this is about?
/ Down again #2
Rolando
Sorry to hear about your continued promblems. I don't know what that error code means.
Maybe we should consider trading machines. My problems for yours. Does that sound fair?
Good luck getting operational.
Cheers Dylan
/ Down again
Well, I just talked to the road tech and gave him the problem code. He looked up the code and said they would have to pick up the machine again. So much for my hope that they could come out and just replace some part.
/ Down again
I'm not sure if I can apply the lemon law because I've owned the Toolcat for nearly a year, even though I only have about 130 hours on it. I didn't use it a lot the first six or seven months, but when I moved into my new place and really started to work it is when problems started up.
They're going to extend my warranty six months, since it's been out of commission for so long. I don't know if I'm just shaking bugs out. I'll have to see how it goes after I get it back. I was hoping for a lot better reliability from Bobcat. For whatever it's worth, it doesn't seem that the other guys in the forum have had as much trouble with their Toolcats.
/ Down again #6
Rolando,
Sorry to hear about your continued bad fortune with your TC!
Steve
/ Down again
Just an update on my problem. They tell me that the problem was that some wires shorted out and it's been fixed. I'm hoping to get it back tomorrow. I've got huge piles of pine tree trunks and branches to gather up.
By the way, on another subject, I decided to follow Dan's (dsb5610) advice and switch the flat head connectors on the hoses to the grapple to reverse the controls. I can't tell you how many times I dumped a load when I wanted to tighten the grip. I decided I'm just stuck on moving the switch to the left to tighten and right to let go.
/ Down again #8
Rolando,
Shorted wires right after having repair work done sounds like someone made a mistake. Hopefully they replaced the wiring harness where the short was instead of patching the existing wires. I would ask to see the repair.
On the grapple, you said you are stuck with it tightening when the switch is moved to the left and opening with it to the right. This is how it works on mine. As I recall yours originally worked just the opposite. Maybe I misread your post. Did it change after you switched the flat-faced ends?
dsb
/ Down again
Yeah, what I meant was that my brain was stuck in wanting to close it by moving to the left and opening to the right. Now that they're switched my brain is in sync with the way the grapple works.
By the way, they tell me that a branch snagged some wire underneath, which is reasonable since I had been crawling over a lot of stuff cleaning out the pine tree crowns that the loggers left behind. Looks like this one was my mistake and I need to take back my recrimination about the reliability, at least so far. Although it does seem that there shouldn't be wires exposed underneath for a branch to catch on. But in any case, I just got it back and I'm back in business.
/ Down again
dsb,
You were saying that your grapple was connected to function that way to begin with. Just out of curiosity, what kind of grapple do you have? I remember reading somewhere that Bobcat sets up their aux hydro controls backwards from what most everyone else does, hence my problem the way the grapple came from the factory.
I wonder if the Bobcat grapple functions the right way (in my opinion) from the get-go?
/ Down again #11
Rolando,
I have the Bobcat Utility Grapple.
Gald to hear you are back in business. Sticks/branches can find ways get at stuff you would never think possible.
dsb
/ Down again
That's interesting, I was wondering if it was the Bobcat grapple that you had. So apparently Bobcat does set up control of it's grapple as I would expect it to function.
Since the couplers I requested for my grapple are the Bobcat flat heads, it looks like it's an issue with my grapple manufacturer not knowing, or not thinking about, how the hose flow relates to the couplers for the Bobcat verses other companies.
/ Down again #13
Rolando.
A very similar thing happened to one of my Toolcats. It's a "B" series with a little over 400 hours.
During a scheduled service, they "power washed" the interior and filled up the fuse box with water shorting out the relays and causing the unit to act the same way yours did. The came and picked it up on Friday and started to look at it on Monday.
Thay are now telling me I have a "Rat" problem. Funny, we don't have rats at 4000 ft. They are saying that the wiring harness needs to be replaced at approx. $900.00 in parts and 4 to 5 hours in labor.
I drove 2 hours each way to look at it yesterday and it does not look like a "critter" as there is no evidence of a nest, etc. I'm going to lok at my other unit (that has less hours) to see if the same thing is starting to happen to it as well. I suspect it is a chaffing issue, and not from an animal. I have pictures they sent me. I would be curious if it looks the same as yours Rolando. When I drove to look at it after the Service Manager told me that it was "Rats", the technician and Service person told me "Rats" don't like wiring....
Tim
/ Down again #14
I am sorry about all of your problems!! I am on my third Toolcat. Bobcat has given me a 3 year extended warranty because of all of the problems. I had metal in the systems of both 2&3. I only have 130 hours on my new #3 "C" series. I love it when it's working!! The cargo bed is now crooked because one of the hydraulics appears to be frozen and it will have to be taken in for service again. I too hope all of this trouble has a happy ending!! fresh2ob
/ Down again #15
I guess I should not complain when I read about the problems others on this site have had. I'm still a little perplexed regarding the "rats" diagnosis. I have check out the other Toolcat and there is no evidence of any thing disturbed around the wiring harness, let alone any evidence of "nesting". When I pick the unit up in the next day or so I think I will take the wiring harness to a client of mine that works in a forensics lab and see what he can make of it. He told me that he can do some tests and tell if it was an animal or "tool" that caused the cuts. Should prove to be interesting...
/ Down again #16
"No rats at 4000 ft"? I have recurring problems with rats chewing through wiring on my PUs and other vehicles at 8000ft! Often there is evidence (sometimes a lot) of nesting and other times not. Some of the wires have been cut so cleanly it looks like wire cutters were used while others have just had the insulation chewed.
I set traps in the engine compartments, wired in place so they don't run off with them (found one 40 ft from the truck with dead rat caught by the leg).
Good luck.....Boy do I HATE rats!!!!
Rip
/ Down again #17
Rats at 10,000 ft? Amazing! I have lived in my town since 1969 and have never seen a rat, either dead or alive. One of my kids is a pest control operator and he has never found/killed one here either.
I have also spoken with other people in town that have had different equipment stored outdoors over the past 30 years, and they have never had a problem with rats or any other critter chewing wires.
It will be interesting to see what my client says. As I mentioned before, there was absolutely no evidence of any nesting, or pieces of the woven loom on the ground, or anywhere else for that matter. It has to be chaffing, or something along those lines.
Tim
2020 CATERPILLAR 306CR EXCAVATOR (A62129)
2020 CATERPILLAR...
KING CULTER FM-72-Y (A62130)
KING CULTER...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2026 Steel Pines Cargo 7x18 Enclosed Trailer, VIN#7FWBE1832T1036525 (A61166)
2026 Steel Pines...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
