Double Tow
/ Double Tow #11
Semi trucks in OR pull tripple trailers... take about scarey... just watching them go down a mountain pass on I-5 makes you want to pull off the road.
mark
/ Double Tow #12
They used to let truckers on the NY Thruway pull a pair of 48' trailers. The first time I saw that my jaw was dragging on the pavement.
About 2 years ago I saw an F350 dually pulling a big gooseneck horse trailer AND a 30' bumper-pull house trailer. This was in heavy traffic on rt 206 in Hillsborough. He was having trouble moving the load and was getting NO respect from Jersey drivers.
No way I would pull doubles in NJ or the northeast.
/ Double Tow #13
My stepfather looked into pulling doubles and from what he was told it goes by your home state. If they allow doubles/triples you can do so from state to state. I'm sure there will be some catches but from the replies its sounds legal and feasable. But just be careful of your weight. From what I've gathered your pulling your tractor on the GN and the dump empty. Then using just the dump when you get to the job. That sounds perfect. I don't have a dump for just that reason. I'm already at my max weight with just the GN. Good luck, Robbie
/ Double Tow #14
Robbie Hegwood said:
My stepfather looked into pulling doubles and from what he was told it goes by your home state. If they allow doubles/triples you can do so from state to state. I'm sure there will be some catches but from the replies its sounds legal and feasable. Good luck, Robbie
Your stepfather was given bad info. PA for one does not allow recreational or personal double towing.
As mentioned, double towing does come up in the RV threads. More than one has mentioned having to drop a trailer then come back for it later with just the tow rig.
/ Double Tow #15
They still do. There are service areas ajacent to many of the toll booths for breaking down the combo's in order to access local roads.
No big deal with the proper training.
/ Double Tow #16
I have a 20+5 Moritz gooseneck. It also has a receiver in the rear of the trlr, it is for raising and lowering the dovetail. The jack locks into the receiver and either raised or lowers the dovetail. Mine is not for towing, yours may not be either. The Old Gunny
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
DEUTZ MARATHON...
2019 Ram 1500 Crew Cab Pickup Truck (A59230)
2019 Ram 1500 Crew...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
