double rears
   / double rears #1
fsteyer
Bronze Member
Vermont
Mitsubishi D2000
Hi -
I have a Mitsubishi D2000. I'm thinking about doubling up my rear tires. Will I need a new axle or can the additional rim be mounted to the weight brackets of my original rim.
thanks
   / double rears
Hi -
thanks
   / double rears #3
If you don't have 2 piece wheels you will need a spacer between the wheels . I intend to do this with mt Hinomoto E264. It has 2 piece adjustable wheels so all I have to do is located another set.
Eugene
   / double rears #4
Eugene
   / double rears
thanks ..
so I need actual tandem rims?
   / double rears
thanks ..
   / double rears #7
No, but if you have welded wheel centers the tires won't have any clearance between them and the wheels won't meet.
Eugene
   / double rears #8
Eugene
   / double rears #9
It is possible (in Norway) to buy (or make) special bolts for the rear wheels. Extension bolts. They lool like long nuts with a bolt in the end. Remove the old nuts, put on extension bolts, one more wheel, and then the old nuts. This looks a bit fragile? but works.
Another solution is to maks something bucket like to put in the wheel center, with a new set of bolts on it.
   / double rears #10
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
John Deere 2010 Loader Tractor (A50514)
John Deere 2010...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
Kubota RTV1100CR9 (A47384)
Kubota RTV1100CR9...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
