Double-ended
   / Double-ended #1
RFB
Platinum Member
None
lift arm pins? Is there such a thing as a (one-pices) long lift arm with pins on each end? I want to construct a ballast box using concrete and wanted a single long rod terminating in pins at each end to span the width of the box.
Thanx
   / Double-ended #2
I used a drawbar. Its a single peice of iron with a row of holes. They have pins on the end cast as a solid piece.
Speeco makes various hitch accessories that are available at many ag supply and tractor dealers:
Speeco Drawbars
- Rick
   / Double-ended
Thank you very much gentlemen!
RFB
   / Double-ended #5
I used a piece of 7/8" steel rod.
   / Double-ended #6
I used a cheap surplus drawbar bolted to the bottom of this counterweight.. etc.
Or as others said... use a 7/8 rod.. or piece of rebar even.
Soundguy
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50322)
2015 Clarke Power...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
2019 Chevrolet Cruze Sedan (A50324)
2019 Chevrolet...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
