Double Chute Snowblower???
   / Double Chute Snowblower??? #1
Klorinth
Winnipeg, Manitoba, Canada
Montana T2334 HST
Is anyone able to identify the snowblower in the attached pics?
I found it advertised on Kijiji near me.
I am interested in learning more about it.
It is 5' in width. The chutes are electric rotation using a chain. That is all I can tell so far.
Any ideas?
   / Double Chute Snowblower??? #2
Looks like 2 30" blowers were joined and made a 3pt mount.
Aaron Z
   / Double Chute Snowblower??? #3
The blower operates 90 degrees different than most. I remember seeing a blower with that orientation a looong time ago. Cant recall how well it works. :confused:
You think so?
The chutes are connected in a pretty seamless way, and it you look closely the top sheet metal is a single piece and not connected. The 3ph mount could be homemade...
I can't be sure though. That is why I was interested in hearing if there is anyone here that has heard of a double chute snowblower before.
How about the style of dual stage? Does that look familiar?
Can you explain what you mean by 90 degrees different? I don't think I'm understanding you.
   / Double Chute Snowblower??? #6
Any ideas?
The twin spout caster will plug less for sure and the tractor can be run more slowly with near zero plugging.
I do no not know the manufacturer but the type has been discussed before-possibly Hesston?, as the paddle wheel impeller was a very simple way to get rid of the snow but it was a bit slower as the paddle wheel impeller was less likely to jam from plugging
The two spout snow caster is a common sight in europe in road snow clearing and also at ski resorts.
Interesting... Now I get the "90 degrees" difference. I had noticed that.
I hadn't thought about the clogging being reduced but I could see that working.
The price is right, so I am tempted to buy it. I just don't know how solid and reliable it will be over time. I am just getting into welding so I will be able to do some work on it and make it stronger if needed, but I would rather not buy something that requires lots of work. I don't have a good shop to work in, I'd have to go to my sisters place for that.
I'll look up the Hesston suggestion.
Thanks.
   / Double Chute Snowblower??? #9
Re: Double Chute Snowblower??? = BobCat
That snowblower attachment was made by BOB-CAT, then also known as Wisconsin Marine. (Not to be confused with the skid-steer loader manufacturer 'Bobcat', which is an entirely different company.)
You can barely see the Bob*caT logo in the 2nd pic, on the chain cover between the two chutes. It's a decal like this:
A buddy and I have a couple of the small walk-behind BOB-CAT snowthrowers. They aren't uncommon in my area, but I've never seen this tractor implement version. It does resemble two BobCat 30" commercial walk-behinds stuck together. I'd gamble the augers and impellers are the same parts between them.
Company ownership passed through several hands to become the present day BOB-CAT turf equipment manufacturer, a division of Schiller. Little is on their website, but you might try writing them for more info:
Our Legacy | BOB-CAT Commercial Mowers
Schiller Grounds Care, Inc.
One Bob-Cat Lane
P.O. Box 469
Johnson Creek, WI 53038-0469
   / Double Chute Snowblower??? #10
Never seen one like it, either,,
but it does look like it could handle snow without problems, do you have a pic of the back.
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
20X 8 SHIPPING CONTAINER (A52472)
20X 8 SHIPPING...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
378753 (A51573)
378753 (A51573)
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
