Double checking my tire needs on BX24
   / Double checking my tire needs on BX24 #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
My property is on the water. Lot's of sand. Some rough grass (which can be soft). And a "Crushed Bank (mix of sand gravel and clay I think)" steep road I wish to maintain with it.
I plan to move lots of rocks. Some on the edge of the water in sand.
I might try to use it to launch my boat.
I may distribute sand and sod with it.
I may use it in the winter on occasion if the plow doesn't show up or makes a mess or I need to access an area not normally plowed. No plans for a snow blower at this time.
I plan to dig out a bunch of stumps.
I may add a box grader or scraper for grooming the road.
No mowing.
I'm thinking turf tires. Not so much to protect the little bit of grass but a lot of land is loose on my property (the sand and the crushed bank road). And I think aggresive tires will tend to dig in rather than try to ride on top.
What do you think?
   / Double checking my tire needs on BX24 #5
   / Double checking my tire needs on BX24 #6
Ken_CT said:
Here is a post from an earlier thread that has an excellent explanation of tire types & uses.
Good info.:D
   / Double checking my tire needs on BX24 #7
Ken_CT said:
Here is ... excellent explanation of tire types & uses.
Thanks mate!
   / Double checking my tire needs on BX24 #8
R4s are the safe bet (i.e prevents you from making an "all-out" mistake). But they might not optimize your potential (like Ags would), particularly in hauling rocks up slopes, towing, etc. From what you describe, Turfs would leave you wanting for more grab.
   / Double checking my tire needs on BX24 #9
That is what I was thinking.;)
FELLA TH800 HAY TEDDER (A51243)
FELLA TH800 HAY...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
TEST YOUR BID BUTTON! (A51244)
TEST YOUR BID...
ATLAS 1985 SCL120 10' ROTARY MOWER (A51243)
ATLAS 1985 SCL120...
2016 Chevrolet Cruze (A50324)
2016 Chevrolet...
